Show me your poke!
GreenVibesOnly
Jake
Seattle WA
4-Door Bronco Badlands w/ Sasquatch + Lux
I like high and tight look with very little poke. 35/12.50/17 on factory optional badlands beadlock wheels. These are not sasquach flares or wheels, yes they slightly rub on the sway bar.
What stripe do you have in the crease there? I’ve been thinking of a black/bronze stripe.
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
Stock wildtrak suspension, sasquatch flares, 35x12.50 nitto ridge grapplers, on 20x10 -18 weld ledge 6.
Ford Bronco Show me your poke! 20220821_164012
Ford Bronco Show me your poke! 20220821_163947
Ford Bronco Show me your poke! 20220819_155443
Ninjak
Miami
chuthis
SoCal
22’ Bronco
Ford Bronco Show me your poke! IMG_7086
17x8.5 -12mm on OEM Goodyears and SAS flares
KABQ
Aaron
Albuquerque, NM
Y'all are soft.
I love the way the body looks, hate the poke. I got tired of my side mirrors and door handles getting covered in crap, and don't want to break windshields, so fenders are going back on.
Ford Bronco Show me your poke! PXL_20240130_202657394
Ford Bronco Show me your poke! PXL_20240130_202717587
Tomleo67
Tom
Mass
22' big bend 4 door
hi, newbie here and also mechanically challenged... I don't understand the offset thing. I have a stock big bend with stock +55 mm wheel offset. Looking to add 20" wheels and 35'' tires with the 2" level/lift. Do I need to try to keep the same offset or change offset? I see most of the wheels are zero to about +20mm. Can I use a zero offset? Or will that poke more or less? please help. TIA
TexHornz
TexHornz
Kyle
Bixby, OK
2022 Bronco
The lower the number the more poke you will see. With a lift, you should be fine with stock offset or lower, it will come down to preference.
Tomleo67
Tom
Mass
22' big bend 4 door
thanks! I'd like to acheive no poke or close to flush with flares
JL8jeff
Ewing, NJ
You probably want to look for a 8.5 to 9" wide wheel and the offset around +12 to +30. When you start to get around -6 or 0 or +6 it will start to poke quite a bit. You may need to run Sasquatch flares as well since they are wider and will cover up some of the poke. 20" wheels might be a little tougher to find the combo you want so post up whatever you find and someone will give you an idea of how much they will poke.
