Shock Recall questions
BamaBronc
7/19 Purgatory
www.google.com
F150 and Edge
Just curious as to what the stealership is looking for on this recall. Here are some pictures of mine currently and was wondering if these look like they are leaking. These obviously are all four corners.
Ford Bronco Shock Recall questions IMG_7439
Ford Bronco Shock Recall questions IMG_7437
Ford Bronco Shock Recall questions IMG_7441
Ford Bronco Shock Recall questions IMG_7443
Ford Bronco Shock Recall questions IMG_7438
Ford Bronco Shock Recall questions IMG_7442
Ford Bronco Shock Recall questions IMG_7440
Ducati1098
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
https://www.bronco6g.com/forum/threads/recall-25s01-rear-shock-absorber-external-reservoir-corrosion-🚨repair-now-available.119852/
Look at the PDFs posted here. It explains what it’s looking for. Basically any cracks or leaks. Without a closer look, I’d assume yours would pass and just get the repair.
Also, your front shocks don’t matter, the recall is only for the rears.
Hey Ducati, is there any truth to the rumor that Ford is reimbursing people that have replaced their shocks with something other than OEM?
Techun
Pa
BD, 2.7, MIC, 4dr
If the reservoir isn't attached, it would fail the inspection.
23OBX2.7
AB Canada
2023 Bronco
I bought the sleeves very cheap and good insurance.
Ducati1098
Yes, if you did before the recall came out you could qualify for recall reimbursement.
