Shift Lever Gear Indicator supposed to be lit?
TheMonk
Dano
2024 Bronco Badlands Sasquatch
I’ve searched and can’t find the answer. Is the P R N D M supposed to be illuminated?
Ford Bronco Shift Lever Gear Indicator supposed to be lit? IMG_2665
Fordified1
Bob
Mid South Texas
It doesn’t need to be it’s on your screen in front of you.
Fordified1
Bob
Mid South Texas
It means you'll never hear a grinding noise from your Chinese made transmission lol
And it means you have 3 more gears and a torque converter that all work together to keep it perfectly in the sweet spot of the torque curve.
tgoat
Tdub
canada
bronco
This is one of those minor things that drives me nuts daily on the Bronco. The gear indicator on the screen is sometimes fully blocked by the steering wheel. It would have been so easy to make the letters illuminated on the shift lever housing and make it super easy to see.
Sgt Badlands
Joe
Midwesr
Lower your steering wheel, don’t drive like a granny
Is there a safe way to permanently remove the steering wheel? To drop excess weight and lower the center of gravity?
Asking for a friend
