"Service procedure interrupted" while using ForScan
Cloak
Nate
2022 Ford Bronco Big Bend 4 Door
I recently got my 2022 Bronco BB lifted with 37" tires. I found the thread of how to configure everything via ForScan but when I go to clear the PCM, I get the error pictured below (Service procedure has been interrupted). Has anyone else experienced this? One video I watched, the guy never cleared his PCM after he recalibrated the tire size, not sure if it was edited out though. I went for a drive and no error codes come up on my dash and the speedo seems correct, but I'd rather have everything cleared if possible to avoid any chance of a dealership questioning me if I need to go in for service or something.
Ford Bronco "Service procedure interrupted" while using ForScan Capture1.PNG
Ford Bronco "Service procedure interrupted" while using ForScan Capture2.PNG
Ducati1098
You already have a lift with 37’s. Personally as a technician, seeing that code wouldn’t make me question anything. I wouldn’t even worry about it.
The only other way I know of clearing this out would be by using the Ford scan tool (FDRS) to relearn module data. Unfortunately that doesn’t really help you. Maybe shoot an email to forscan and ask them for help. They’re usually pretty good about working through things like this.
ā€˜21OBX
90Bronco19
2022 bronco outer banks
