Seatbelt Notification - How to disable?
X-rated
frozen north
25 base Squatch 2 door
Yep....worked on my 2 door '25. Thanks guys!
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I figured it out!
On a 2025 the dash indicator never turns off. You just need to run the 4X buckle/unbuckle procedure immediately after entering accessory mode. Don’t wait.
Unfortunately, I don’t think there is a way to access the center screen and bypass the X seat indicator unless you buckle up. Anyone know otherwise?
Now onto “key in ignition” and “no key detected” chimes.
