Auto Start / Stop - how to permanently disable?
Kreation
Edmonton
Reading the reviews for the Amazon products comes up with problems with the power windows and mirrors after installing. Doesn’t seams like it’s worth it.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
2022 Ford Bronco Badlands Sasquatch
Herexs what I can explain:
Forscan ---> PSCM ---> Find 730-03-01 ---> Third Set of Numbers update the first two characters to "00" to disable. Write to module and exit.
What I can't explain:
7 pages of posts by forum members pissing in the wind with unrelated comments to get the OP's question answered.
Epiphany
Upstate
'24 Bronco
Does that PSCM tweak work on 2024 models?
Green/22/Bronco
East Haven, Connecticut
Ford Bronco
This is false..
Read up on the The Magnuson Moss Warranty Act
The MM Act was put in place in the early 70’s to protect one from not using factory replaced parts like fuel filters and spark plugs. It was never meant to protect one from making changes in the car’s computer to non specs. So the MM Act is useless here.
raqball
Kris
WA
2023 Ford Bronco Badlands 2DR
Again, this is false!
A manufacturer can't void your vehicle warranty just because you made a modification. The burden of proof that the modification caused the failure is on them.
If you upgrade your seats they can't void your powertrain warranty.
Please stop posting incorrect information.
Green/22/Bronco
Ford Bronco
The burden of proof is on the individual to prove their modifications didn’t cause the issue. Because in the end the dealership will just refuse to work on your vehicle.
raqball
Kris
WA
You can't be serious? The burden of proof is on the manufacturer who is denying the warranty claim..
Please don't post false information as it's not helpful to others.
PrepVet
North Central WI
A bunch.
Altering your vehicle before the end of the is warranty will void it. Reach out and just press the button.
Dude whatever you are smoking you need to share. Cause you are making so little sense here you have to be flying with Puff the Magic Dragon over the Land Called Hanalei.
PrepVet
North Central WI
A bunch.
In fairness the window issues are a factory feature, not a bug. ;)
Trail
Tyler
Canada
F150, Ram 3500, Honda CRV, Charger Hellcat RE
Actually, it would only void the warranty of a certain aspect of the vehicle, it adversely affected, and caused failure of. For example, if you altered the cooling system in such a way as to cause the engine to overheat, and it blows a head gasket, that head gasket wouldn't be under warranty then. But if you altered the rear tailgate latch, and the engine were to overheat, blowing a head gasket, the head gasket is still under warranty, because that tailgate latch, has nothing to do with the engine overheating. It has to be causational, and the automaker has to show how. To tell people that any modifications, cancel their warranty, is false information. If such were the case, we wouldn't be able to change tires, brake pads, batteries, wiper blades, or install a winch, or even seat covers, without voiding our warranty. Making such false claims helps nobody, and further spreads misinformation, so please do not do it.
Billison_
Las Vegas, NV
2024 Bronco
Why don’t we stay on topic and not share shinfo… no one is asking about warranties, people are asking about disabling start stop. Maybe just say your warranty comments out loud to yourself and save the bandwidth.
DemonGT
Dan
Wisconsin
2022 Badlands
can Forescan turn off ASS on '22 models?
Brisco2
NJ
2012 F350 XLT, 2018 Ford E350
DemonGT
Dan
Wisconsin
2022 Badlands
