seat belt reminder
Valhalla
Valhalla
Chattanooga Tn
Mine worked remove the rear seatbelts and it will disable the air bags. To the seatbelt guy. I ride motorcycles. I don't need a better cage. I get if that is your choice but the data you rely on is speculative. You cannot definitely say having g a strap on saved this persons life. You can only speculate.
ssitruc
Oklahoma
'25 Bronco Badlands
I found these instructions in the manual, and tried it twice, but it didn't work.
It worked for me, but it took a few times... because of step #2's "wait a short period of time until..." WTF is a "short period of time"?? I waited I think 5 seconds or so. Also, in #3 & #4 the "seatbelt warning light" is the little red dummy light, not the "ok" screen. The confirmation that it worked was the little red dummy light (#4) flashing rapidly 3 times. Then it is the same process to re-enable it if a person wanted to.
FoCoBronc
Colorado Springs
‘26 BL - previous ‘22 OBX, Tacoma, X3, MDX, Bronco II
We’re talking about 2 things here. This hack does eliminate the chime, which in the past required forescan. However, unless I missed something, it does not eliminate the little 1 min infotainment message unless u press the ok button.
FoCoBronc
Colorado Springs
As an aside, I think, but not 100% sure, when you adjust key-door lock chirp it also eliminated double honk. Mine no longer double honks and that is only change I can think of. Again, in past forescan was needed to do that.
