Scotch Blocks
mcinfantry
Lee
Louisiana
Badlands 2 door
So does anyone think it would be ‘possible’ to use the front toe /rear recovery hooks for scotch blocks for winching/recovery?
or are you just going to bend the frame?
Mudlight
Brent
Badsquatch
Who knows? I hope not. I did the LOD reinforcement frame brackets for my RC high winch mount in the front. I have a hitch receiver mount recovery shackle insert in the rear and the supplied Ford tow loop in the rear also. Those are probably ticking time bombs. Lol.
Ford Bronco Scotch Blocks 1686081255285
JohnnyBronco
Pennsylania
X4
At the very least the recovery hooks one at a time are cap le of yanking a Bronco with full locked brakes up onto the bed of a rollback. Or they wouldn't be labeled "recovery"
mcinfantry
mcinfantry
Lee
Louisiana
Badlands 2 door
I’m genuinely interested if they could hold the bronco and not deform the frame
@BigMeatsBronco
@Tex
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
Neat for me please.
Theherofails
Thomas
Phoenix
I had an F-250 giving it all she had for 6 solid hours tugging my Bronco out of quicksand.. Just absolutely brutal on the F-250. Full sprint pulls with and without a kinetic rope. 15,000+ LB dynamic loading repeatedly for 6 hours, easy. Zero issues. Every angle you can think of.
The recovery points are 100% fine.
RHeinz
Ric
Houston, TX
Unless you were using a remote mounted winch, why would you attach the snatch block to one of the vehicle recovery attachments? Wouldn’t the snatch block go on the “dead man” away from the vehicle/winch?
You could always use a bridle between two recovery points with the snatch block attached to the bridle if using a remote winch.
mcinfantry
mcinfantry
Lee
Louisiana
Badlands 2 door
What is a "scotch block"? do you mean snatch block?
Blocks/braces you chock your wheels with, prior to hydraulic rams on tow trucks they were used
I’ve used various objects in the past as suck on a deuce and 5 ton and m715
Just curious for those of you more familiar with this platform
you anchor them to the tow points and the truck digs instead of slides
Ford Bronco Scotch Blocks IMG_1470
mcinfantry
mcinfantry
Lee
Louisiana
Badlands 2 door
Not snatch, scotch
See photo
Chrome_Pony
Chrome
The Great Land
I use metal spiked wheel chocks for winching on snow/icy pavement up here, similar concept, minus the attachment point.
Can't see how the load would be too much for a recovery point since even on a hard pull, the load on the point from the scotch would never be 100%
mcinfantry
mcinfantry
Lee
Louisiana
Badlands 2 door
Thanks! No you didn’t need to anchor them to the veh to dig?
I’m trying to learn a little about the platform and also trying to rig my sand ladders if possible as scotch blocks in a pinch
Bikeric
Tulsa
2022 Badlands LUX on 37's
I learn something new everyday on this site. I know that “traction boards” were useless for me in the sand. I’m going off to research more on these scotch blocks.
