Sasquatch seems like alot$
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
Interesting. How is it better for you ?
Eats up bumps way better than the stock suspension. Stock suspension was fine, but the SAS is way less bouncy. Couldn’t believe the difference, my son even noticed and commented on it. The 4A is another benefit that’s included in the SAS and not an additional cost like other trims.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Thanks, makes sense. How is road noise with the more aggressive tire ?
stickshifthappy
RVA
Base gearing is 4.46 (unless one picks the automatic transmission)
On the Badlands the 4.7 is stock (at least with the 7 speed). I think the Badlands has many of the features already included you get only when you move to SAS on some of the other platforms. I'd swear I've heard that quoted a few times on some other sites.
BigBendBW
Columbus, Ohio
Yes, the Badlands is the only trim I’m not sure the SAS is necessary because it’s already the same suspension. Just if you want the different wheels and tires mainly it seems.
stickshifthappy
RVA
I expected way worse, it’s totally fine and I think even quieter than the Grabbers standard on the BD.
Glad to hear it's working for you. Another satisfied Bronco owner !!
stickshifthappy
RVA
It's really nice 'cause if I wanna go DIY SAS, I think all the guts are in place. And based on your ride review, it's gonna be your fault now if I do.. ;)
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Correct I guess thats a question for the OP. With a manual 4.46 you’d have no issues running 35’s and if they aren’t hard core off roading 35’s will fit right in with crash bars removed. For me as a daily I wouldn’t consider a manual any more. My commute is stop and go nothing over 40 mph not worth the hassle of a manual. If it wasn’t a daily driver my view would May be different.
mpeugeot
It’s my built and this is 100% on point. The ride of a SAS is simply way better than a non-SAS. I didn’t think it would be as big of a difference as it is but it’s SAS all the way for me.
On the highway, I would seriously doubt that, the OBX probably has the best road manners.
I say that having had a stock OBX that is now running the yellow Bilsteins and appropriate springs.
Off-road, yes, the yellow Bilsteins and matching shocks are the better choice.
mpeugeot
So to the original question, the value of the Sasquatch package.
Excluding the Badlands (or package which comes with the sasquatch package standard). The Bronco's capabilities on non-sasquatch Broncos is reduced depending on the trim and configuration. Upgrading the differential(s), transfer case, suspension, wheels, and tires via the sasquatch package is anywhere from a good value to a great deal, as long as you want the whole package.
In the Badlands - it isn't a good or great value, UNLESS you want the Sasquatch rims and tires.
Personally, I didn't want to run 35's, 4.7's, and I didn't like the rims or tires with the Sasquatch package. I wanted lockers, but I also wanted carpet, a cloth interior, and adaptive cruise control. I was somewhat screwed and had to decide on what compromise I would accept.
Ford Bronco Sasquatch seems like alot$ IMG-860723beae5a722673cca1088b9465a3-V
In the end, I ended up ordering the OBX with the rear locker, advanced 4x4 transfer case, and lux package. The 4.27 locker is plenty to run 33.5" tires even when running around Colorado (above 7,000'). I didn't get the sway bar disconnect or the front locker. I was initially bummed that I couldn't get everything that I wanted, but in the end, I was happy with what I ended up with.
Ford Bronco Sasquatch seems like alot$ IMG_20221006_185615
The advanced 4x4 transfer and rear locker only added $1500 to the price. The 4.27 will run a wide range of wheel/tire combinations with ease. I addressed the suspension "short comings" by installing the Badlands shocks and springs. I have wheels and tires that look amazing on the Bronco (plus an extra set of wheels/tires for highway/economy use - 23 mpg at 70+ mph). It has been brilliant for the 41,000 miles that I have put on it so far.
Ford Bronco Sasquatch seems like alot$ IMG_20221009_115443
Pikes Peak 14,000+ elevation.
I don't regret that I went non-sasquatch, but I also realize that I sacrificed some capabilities and some resale value making the choices that I did.
BigBendBW
Columbus, Ohio
I’ll own it! You are good to go with a Badlands for sure. If I would have stuck with a non SAS I would have done the Ford lift kit if it ever gets released. Supposed to rival the SAS.
