Sasquatch package + Lift: What is the recommendation to add 37's?
1979
Baltimore, MD
BlueBronco
DFW
great info, TY! What tie rods you buy? stock or the RPG ones?
Currently, the only inner tie-rod's available is the Ford OEM one (and those appear to be on back order). RPG only has the outer rod.
Bradley Thornton
Bradley
Hattiesburg MS
Bradley Thornton
Bradley
Hattiesburg MS
still happy with your set up? I need the extra articulation for what I am doing but your ride looks rad!
Yes 100%
What lift gives you more articulation than stock?
Without the sway-bar disconnect no way you rub with my setup ever.
My opinion is go with 1in leveling kit or 3in spacer lift by Zone if you want more hight.
Why?
it cost less
better ride then others
But you know what they say about options
Ford Bronco Sasquatch package + Lift: What is the recommendation to add 37's? Suspension #s
69BroncoX302
1969 U15, 2021 First Edition
fully upgrade tie-rods and steering rack, lifts and anything higher then 35's appears to set off angles just enough to break both. There are links for people developing new rack and rods for lifts and tire upgrades. only reason why I haven't put on my lift yet.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
Did you do anything aside from changing the coil overs? Diff drop, upper control arms, etc?
We're also going with the Camburg billet uppers and billet trailing arms.
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Dirtyjed
Orangevale
05 Dmax, 86 FunRunnah, Tiyoda truggy, Honda shi
Check out the Fun Haver stuff. Not out yet, but Loren Healey is behind it so I imagine it will be correctly thought out and come at least moderately tuned.
I looked at the Camburg stuff and the zone stuff and am holding out.
I wheel JV a few times a year and it will skew your idea of what is moderate compared to most other places.
Definitely upgrade the steering, main reason I'm still running 35's.
Also Metal Cloak has an undercarriage bash kit in the works that looks pretty legit.
HardenUp
Shane
Fort Mill, SC
First Edition 2021 Bronco
What you really need for 37s is an upgraded steering rack and/or tie rods.
Yup, This and new CV axles. RCV is coming out with some. Pricey but you’ll be less likely to be stuck on a trail, which if you’ve been there before - sucks and worth the price for stronger components.
RainbowStix
A Big Island
Toyota Tacoma
I’m running the icon 3” spacer lift which seems ok for 37s. I did have to get a set of aftermarket UCAs to get it to clear the back fender liner at ride height though. And when you’re wheeling, expect it to rub wherever it can
Lurker B6G
Murph
Cleveland, OH
Ford Explorer Timberline
Yes 100%
Why?
it cost less
Ford Bronco Sasquatch package + Lift: What is the recommendation to add 37's? E730A7D6-504C-4EAF-95CF-18727768EA9F
Spot on with what is said here...
I would add that if you are looking at one of the smaller 37s (i.e. BFG's), then the Zone 2 inch SAS kit (ZONF1221) looks to be about perfect. Same amount of spacer lift as the 3 inch kit, but only 0.5" of spring preload. This will keep the ESCV near the middle of its range which is paramount to their design.
mike8675309
Minnesota
BroncBuster recently made their 1.5" and 3" body lift available, including relocation brackets for the bumpers. They also released a video on their youtube channel showing how to install it in your garage.
A body lift seems like a no-brainer for a sasquatch owner to fit 37s. There is no need for new suspension parts, you don't throw away the good stuff you already have, and the geometry stays the same (warranty!). You could get your own kit built if you have access to a job shop, but it would be hard to beat BroncBuster's price (though I haven't checked shipping costs). It's the approach I plan to take, and that was before this kit came from BroncBuster. It still wouldn't hurt to find a local job shop, because depending on your bumper, you may need some custom relocation brackets.
https://broncbustertx.com/products/bronco-body-lift-kit
Regarding articulation, the sasquatch has bigger bump stops that limit articulation. Order some Badlands bump stops and swap them out or if you need more articulation pull the bump stops out, find out how much room you have, then get some custom bump stops made. It's a foam which you should be able to duplicate, just build a form and make your own compressable bump stops.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
That's already happened once. I got high centered a few times on a trail in Johnson Valley
Well, I did. I went up Mottino Wash and had to be winched off one rock garden and lifted off another one so we could add rocks under the tires.
Even after you upgrade, you will still find locations in Johnson Valley where you can get high-centered, because there is not that much difference in ground clearance between a vehicle running 35s vs 37s.
The Sasquatch package is more than capable as is, even in Johnson Valley, but needs to be supplemented with recovery gear and careful lines/spotting to avoid high centering.
I would suggest investing in a winch and choosing lines more carefully before you upgrade to larger tires and a more expensive lift.
