What is the best lift out there for sasquatch package to run 37's .
Broncridin
James
Houston Texas
Ram 1500
What is the best lift kit out there if you already have the sasquatch package. I'm looking for a 3-4 inch bolt on lift that is good but won't break the bank. I like the Baja kit that basically changes entire suspension and is 12k. But for now just wanting something without changing shocks etc... I've got a 2021 4door cactus gray first edition. Planning on 37's in a few months ,so need a lift that will accommodate them. Anyone making a 4" lift for the sasquatch?
dan79
dan
ma
08 f250
I did the icon 3inch spacer could run 37s with that then I just did the broncbuster 3inch lift that you could do yourself
I need to do my tires it looks like my bronco skipped leg day lol
j_marinelli
Spring Branch, TX.
I went with the Zone kit. Main reason is it comes with the control arms so when if and when you do decide to upgrade, you can already check that part off the list.
Cobrafang
Thomas
GA
I have the rough country 3.5" kit works well. I want to change to the HOSS 3.0 set up should be same but give more travel.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Ford Bronco What is the best lift out there for sasquatch package to run 37's . IMG_5294
Can you show me some more pics of your ride with the bronco buster kit? How difficult was the install?
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
currently installing fab tech 4 inch lift on mine. That body lift above looks wrong withthe space between the bumpers. Doesnt look right
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
1.5" body lift from Bronc Buster. Cheap/easy/effective. Call and ask them yourself.
dan79
dan
ma
08 f250
my ista
my install was going great until the last bolt in the front passenger side that was stuck and wouldn't budge. once I got that out super easy install would have been an hour but with that it took me like 4 hours.
the have a video up that shows everything. I did it with the jack that comes with the bronco and a few 2x12 cut off pieces of presser treated I had in my garage
I will try and take some more pix i haven't had a chance
I think if I could install it you could do it on ur own really was not hard at all
dan79
dan
ma
08 f250
u can run way bigger tires getting further off the ground
Dubsesd
Andrew
CT
my ista
Ford Bronco What is the best lift out there for sasquatch package to run 37's . IMG_4004.JPG
Thank you. If you can pm me the video that will be great.
BigGarnet
‘21 Bronco
Does what have any benefit off road? Running 37s? Absolutely...major benefits. Lifting more than is needed to fit 37s? Some benefits, some drawbacks. The suspension lift gives much better clearance of the sprung parts of the vehicle. It improves approach/departure/break over angles significantly. Obviously it doesn't lift the axles, only tires do that, but it lifts the parts that often get hung. It helps a lot on a vehicle like Bronco with a low slung "belly". To you point, the drawback is a higher center of gravity, so it's a balancing act on what you want, with drawbacks and benefits to both approaches.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I'd only consider the Broncbuster 1-1/2" body lift at this point, until a solution for the drive/steering geometry is addressed properly.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Better a space than bad axle/tie rod angles! lol
