Rough Country trailer hitch installed
Wolford678
J
GA
‘21 Bronco Badlands
My second accessory added is the rough country trailer hitch. It bolts on the to frame behind the rear bumper with four bolts. Yes I had to remove the entire bumper to install it even though I saw YouTube videos of people with similar hitches slipping the bolts on with the bumper still on. There was not enough room for me though I tried many times. Getting the bumper back on by myself was not easy.
Then I got a parking sensor fault warning and the whole system, front and back, stopped working. I took the bumper off again and checked the connections.
day 3 I sprayed wd 40 on the two main harness connectors on either side. I also pushed down a little white piece inside the connector trying to see if it was misaligned and blocking.
I’m happy to say it works now for the time being. But I broke the clip off on one of the main connectors while removing it. So it may vibrate loose. I may try to buy a medium size zip tie and somehow wrap it around it. I’ll add the trailer break light harness at a later time. I’ve only tested the parking sensors once by backing up in my garage. Hopefully they’re permanently restored.
Ford Bronco Rough Country trailer hitch installed IMG_9580
dgorsett
colorado
F250, Mustang, Explorer
I've had some difficulty with factory plugs and the zip tie trick has always worked.
I had the same issue when I installed my hitch, and a ton of people screamed "You don't have to drop the bumper!"
Hitch looks good
