Rough country rock lights
62chad
CA
2014 ram 1500
Anybody install them that has the accessory switches? How did you wire them? The harness is made for their switch and I can't seem to figure out how to modify it to work.
Ford Bronco Rough country rock lights 20220814_083939
Ford Bronco Rough country rock lights 20220814_083912
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Yea I have on a couple of Broncos, the lights have a pig tail that clip into the harness that comes with the kit. I clipped the harness on then cut off the remainder of the harness. Then wired the positive to six switch wire and grounded the ground. Hard to explain. If you post a pic of the harness laid out I can mark where I cut it.
Ford Bronco Rough country rock lights 9DDF6F05-714D-4947-B8DE-14710C285D0A
Ford Bronco Rough country rock lights AFC00B9C-F81A-4EAB-BD8C-0E5C2C8B9BBB
62chad
62chad
CA
2014 ram 1500
Is that for rock lights or the pillar lights.?
Dubsesd
Andrew
CT
That’s for my ditch lights, but cutting the harness and wiring to the aux switch is same idea as I did there. Also I have a 20” light bar same thing by cutting the harness.
bulldogg915
Mitchell
Omaha
'23 Badlands
How did you end up gettting this to work? What’s hooked up to your aux switch? I thought it would be simple like my other aux switch hookups, but I’m getting no power.
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
Remove the relay and the supplied switch and then wire the positive red wire to the desired AUX switch, then black to chassis ground
This! I just cut the harness right at the relay and then connected to the Aux wiring at the fuse box.
GoHawks63
George
Metro Detroit
Which wire on the truck are you connecting it to? If you're connecting to the factory wire in the front, near the hood latch, you have to find that same wire near the wires by the fuse box and connect it to the correlating wire for the Aux switch.
That wire near the radiator is not powered until you connect it to a powered wire near the fuse box.
bulldogg915
Mitchell
Omaha
'23 Badlands
That’s exactly what I did- snipped the harness and then black to ground and red to my aux 5 (blue w orange stripe). Super simple right? Nothing…It’s driving me crazy. I have 3 other aux hooked up that work just fine and easy to hook up. And no- not using/trying the purple one up front.
GoHawks63
George
Metro Detroit
Hmmm..... Not sure what else to suggest besides the obvious of checking the fuse and ensuring that your connections are good. I used heat shrink butt connectors and a couple of times that despite crimping the connector and then heat shrinking, the leads slipped out and the wires weren't actually connected.
bulldogg915
Mitchell
Omaha
'23 Badlands
Thanks for the help . Yep checked the fuse, and good connections everywhere. Tried connecting to other aux lines too. I'm stumped.
GoHawks63
George
Metro Detroit
Maybe the harness is bad?
Just checking - you do have Key On right?
Also, check the light just by taking it straight to the battery - can just touch it to positive terminal and make sure it comes on.
I hate those crimp butt splices, unless you have the proper tool for them (and high quality splices) they are mostly junk. I usually end up soldering for wire splices, but I admit I've used Wagos as well for connections where I want to be able to disconnect. I should use Deutsch connectors, and I have a set, just been lazy and the wagos seem to do well in non-weather areas once they are taped up.
