Roof Sunshade For Front Section Only
I recently just got this one for my 4-door: Amazon.com: Hoolcar Front Top Sunshade Mesh Bikini Top Roof Sun Shade- Blocks UV, Wind, Noise- Insulation Mesh Compatible with 2021-2022 Ford Bronco : Automotive
Needed some of the bungees shortened to work right, but gets the job done with some slight modifications. Not great, but good enough to keep direct AZ sun off.
I got the same thing - it's just a generic piece of shade cloth with some bungees. I don't see any reason it wouldn't work with the 2-door as well.
Works well with my Rally Top when I have the front off, but I had to pretty much ignore the instructions and just bungee it as it needed. I cannot leave it on when I put the top back on, it's either the top or the shade. Fortunately the shade takes like 2 minutes to install. That may be different with the factory top though.
That said, if your aim is 100% block, this may not be for you. It does leave gaps around the edges.
Fordified1
Bob
Mid South Texas
How very helpful…not!
Why was that not helpful? I see no reason for a bikini when running just the front panels works as well or better. And no flapping material over your head. And are you the OP? Didn’t think so.
dbpnz
Chicago
23 Outer Banks 4D
Hey mate. I went with the Alien Shade front row mesh for a JL wrangler (https://a.co/d/0dcisuXo) and it fits my 23 OBX perfectly.
I added polymer hooks (https://a.co/d/0gCJZLWD) to 4 of the bungees to allow it to grab the holes in the outside of the door pillars at the front corners, and in the center above the dash. I also added hooks to the rear-corner bungees to easily get at the holes above the middle door pillars without taking the middle row top off. A few knots to get the bungee tension just right, and voila - looks like it was tailor made for the bronco. Fits great, sits nice and taut, and does the job perfectly.
Strong recommend.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
Any reason not to get the full shade? It just sits above you when the roof is on. And it’s there regardless of how many panels you take off.
Well, at least the full shade I have won't work with the panels on - it hooks into the panel mount points for full coverage up front.
Shazamalingo
West
2022 OBX SAS
Ah. The Bimini sunshade lets you keep all the panels on or take them off. You never have to touch the shade once installed. Could be an option.
