Roll cage?
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
If you are looking for a true off-road roll cage, most people have them custom fabricated. They basically build them inside the vehicle. My experience comes from the Raptor world. Maybe some Jeep guys will have some other solutions.
You should change out your seat belts to a 2 or 3 point harness and race seats to avoid hitting your head on the cage in the event you roll.
labattbluebronco
Tom
Hobart, WA
94 bronco, 18 silverado, 11 taurus, 01 wrangler
I second the above. Haven't seen any aftermarket "kits" for a roll cage. If you want true rollover protection, you'll need to have one fabricated. I would think there is a shop near Boise; my local shop can custom make just about anything. https://www.xo-fab.com/ No affiliation, just a customer.
Oldhippie
Barry
Santa Cruz, Calif.
So you folks are saying all the “bars” already there are non functional?
Seatmandan
Dan
'21 Bronco, '11 Ford Edge, '10 Ford Fusion Sport
Are there any aftermarket roll cages? I don’t trust the soft top to protect me in a rollover situation.
What are you talking about? The entire upper body structure is constructed with boron steel, and meets federal rollover standards. It's an integrated roll cage.
Seatmandan
Dan
The entire roof system structure IS the roll cage. I know this for a fact.
BCnAZ
Mesa AZ
Ram 2500 Crew 4x4 Limited
MythlinMasterdo
Boise Idaho
2.3L 7MT Bronco, Lamborghini Urus, McLaren 765LT
The stock support absolutely will not keep you safe in a high speed desert rollover. Better safe than sorry when it comes to your life, there’s a reason all actual off road vehicles has several inch thick roll cages.
Bronco-ocnorB
Luke
DFW
Ford Flex
Seatmandan
Dan
Mmmm, you might want to ask Ford about that.
EDIT: According to you, the Raptor is inept, and Ford under-designed/engineered it for "high speed rollovers" and anyone who buys one is just waiting to die in a rollover.... unless they outfit it with some over-engineered, over-sized Mad Max cage contraption. Law-suits waiting to happen, I guess
MythlinMasterdo
Boise Idaho
You obviously haven’t seen people die in rollovers off roading before. If the roll cage that ford built was so good then the factory Ford racing Broncos wouldn’t have roll cages 😉
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
BC overlanding
IN/KY area
As others have stated you need to talk to local fab shops or better yet a buddy that can weld really good and break out that wallet. 😬 Any aftermarket bolt on system isn't going to provide any better protection then how it comes from factory and if you need that kind of roll cage you will need 4 point harness for sure
Rick Astley
Up Doug's ass
d
That the factory sports bars comply with NHTSA requirements and IIHS ratings is not in doubt.
And that it (the factory sports bars) won't comply with SCORE or SAE regulations is also not in doubt.
Perhaps instead of the long-winded back-and-forth of @MythlinMasterdo asking an open ended question, then getting upset with the answers, we could cut to the chase?
@MythlinMasterdo what organized racing are you planning on doing, and what is their governing body regulations for which you're confused about the roll-cage requirements?
This will guide us to give information to a shop which will be able to build a certified roll cage for the racing you're planning on doing. Obviously, this will have to be something replaced/updated whenever the regs change. But let's all be thankful it's not SCCA cone racing or your cage would need to be warmed over constantly!
There are essentially zero bolt-in roll cages which will provide you enough safety beyond what the boron-steel sports bars are giving you. Perhaps something will come out eventually, but the bolt-in cages are seldom the proper answer to the question you've been beating around the bush in asking, vaguely.
