RokBlokz Mudflaps Review
TX-Hans
Yes although I don’t mind the angle as much as I mind the fact that those put holes in my wheel wells.
We are definitely beta testing this ultra high price product. I usually research well what I buy and am therefore rarely disappointed. People around me come to me for advice and recommandations. I am gonna be honest, I feel ashamed on that purchase.
I saw all the rock chips issues and got so much mud and snow build up when using the Bronco, I just rushed on those when they became available.
At the end of the day they still do the job. They protect the bronco. But they have several issues that should not exist at $300 for a pair of thin plastic flaps.
That's worrisome. Following this to see if @rokblokz jumps in here to provide a solution. With this newest fitment issue, I'm leaning a bunch toward sending mine back for a refund since they are unopened. Guess I need to look into the time frame for that and how to return but holding out hope there might be a solution soon so I don't have to.
CTwaterfowler
Roger
norwalk ct
tahoe
got my email. my mud flaps just shipped . 13 days after i put in the order-- thats good for me
original mud flaps /long
also my permanent mounting screws shipped 2 days ago.
looks like i will finally have flaps on the front. will post pics when I'm done
Samsquanch75
Neil
Eugene OR
2021 Bronco Sasquatch 4dr, 2018 4Runner TRD OffRd
Installed the RokBlokz on my Sasquatch Black Diamond. I’ve had their product on my 2018 4Runner since new and over 112k miles on the ODO, I like the look and they are durable as heck. Install did take some time with all the little parts to assemble and they apparently forgot to ship the large bolts for the front brackets since I do not have intrusion bars, being a Sasquatch. I replaced the front flap thumb screws with regular SS pan head Allen screws and some washers as well for more clearance. The thumb screws were incredibly close to the tire as I cycled the steering. I also added an upper screw affixed to a nut plate added to an existing hole in fender where a plastic tab held the liner in place. This upper hole I made in the flap is slotted to allow movement between body and frame since the main flaps are mounted to the body. Rears are installed per the instructions. There is no sloppy play between the flaps and mounts. Also no noise on the road from the flapping around in the wind, I’ve driven over 600 miles since installing. I have slightly wider offset Method wheels compared to factory and the tire/tread coverage from the flaps is adequate.
Ford Bronco RokBlokz Mudflaps Review F722B611-AEDD-4450-BADA-9F133C36E091
Ford Bronco RokBlokz Mudflaps Review A364666C-75C5-4F9F-A469-FC8E7BCE7506
Ford Bronco RokBlokz Mudflaps Review 59E233CA-7D0B-4092-9B44-B0C4A3F451B4
Ford Bronco RokBlokz Mudflaps Review DB9E3166-9C84-4466-863E-337D740A4A8E
Ford Bronco RokBlokz Mudflaps Review 06B183A9-2BD4-4C3F-B3FA-74ADBE8467DB
Jr87mustang
Josh
Northern Cali
Jeez, I just threw the brackets on 2 weeks ago and walked away. Can't believe so many are having problems.
DenverBronc
Luke
Denver
I had a heck of a time getting the hex nuts seated into the flaps and eventually had to use pliers but otherwise the installation was smooth and I have no complaints so far.
Ford Bronco RokBlokz Mudflaps Review PXL_20220428_232025072
Ford Bronco RokBlokz Mudflaps Review PXL_20220428_232112766~2
Ford Bronco RokBlokz Mudflaps Review PXL_20220428_232041742
Ford Bronco RokBlokz Mudflaps Review PXL_20220428_232052951
Hitemstiff
Tyler
Idaho
21 Badlands/ 05 Expedition/ 77 F150 Ranger SB 4x4
For the hex nuts I had to use a hammer/punch and a whole lot of patience. Good to see that they squared up for you.
Hitemstiff
Tyler
Idaho
@broncosor @Hitemstiff and @AK SNO RIDER - Have you guys had any success resolving the fitment issues above for the front flaps?
Not yet. I removed the plastic well liner screw and that made no difference at all. The only way it will work for me is if I mill out the bolt holes, then I'm afraid I wont be able to return them if I do that. This pic shows where my bracket needs to be, and the holes are not lined up.
Ford Bronco RokBlokz Mudflaps Review 20220429_125932
Hitemstiff
Tyler
Idaho
Looks like the sasquatch flaps are no problem since they have all that extra rigidity. The non sasquatch has that hole cut out for the crash bar, giving it a lot more play.
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
Anyones order not come with the M12 x 90mm bolts? Just opened my box and everything was there except the big ol bolts. I have a Sas and did include that info so they should have been provided. Everything else Sas specific is here. If I were to find my own, should I find the bronze coating or will zinc be adequate?
Jjt24
JJ
Toledo Ohio
Escape, Mustang
I would contact them, I'm pretty sure they'll send you the bolts.
[email protected]
Herbie
Alex
Cleveland OH
2022 Badlands
Mine installed fine, they do sit at a bit of an angle, but I don’t think it detracts…better aerodynamics! lol
And they are solid!
Mine are great, not quite sure why everyone is having problems. I can't be happier with them.
