RockJock front AntiRock- which hole?
Sloth
SWFL
2022 Bronco
The RockJock front AntiRock has three holes in the sway bar arms for the end links to attach to. Which hole are you all using for your setup? I assume the hole selection affects the stiffness of the setup with the hole at the end of the arm being the softest (highest leverage). The online install instructions show a picture using the middle hole. My shop installed using the third hole from the end (stiffest/lowest leverage).
Ford Bronco RockJock front AntiRock- which hole? rkj-rj-282101101_xl
Fordified1
Bob
Mid South Texas
You are correct on which hole is soft vs stiff. I don’t have one, but if it’s easy to swap holes, I would put it in the soft setting for crawling and stiffest setting on the street. I don’t run a front sway bar at all, but my hard cornering ability suffers quite a bit.
One more upgrade
Joe Mogush
22 Tesla Plaid X 22 Escalade
I run the middle front and rear. It handles like a Bronco should on the street and off-road, and it has been great. The Antirock is an excellent product; it just works.
Sloth
Sloth
SWFL
2022 Bronco
Any tips when changing the sway bar position? Can I do it with the vehicle on the ground or do I need to lift the front end? I assume the links will need to be adjusted for length too.
Fordified1
Bob
Mid South Texas
Park it on flat concrete and it should be easy to take the bolts out. I doubt you’ll need to adjust the length. Remove both sides before trying to line up the new holes.
One more upgrade
Joe Mogush
I sent a DM for him to watch some of the Curry videos on setting up a JK. I could not find any Bronco ones when I installed mine. Adjusting for a lift if you have one is important as well.
