rocker body appearance kit from Ford
CalvinT
Calvin
Phoenix, AZ
Wish they had that before I had ceramic coat applied.
texastob86
Terry
Sherman, Texas
Ford Bronco Outerbanks
I got PPF applied in the same area to protect the paint. I don't remember what it cost, but that is another route you could take.
Rob Binsky
Rob
Montana
2023 Bronco Wildtrak Sasquatch, 2025 Bronco Sport Outer Banks
I will be watching this thread closely. I’ve had the same question on my mind. I also wonder if it will quiet the noise from the rock pinging (Wildtrak Sasquatch)
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
I had a full body PPF installed on my WildTrack and also got the pinch weld covers from DV8. The only thing that helped with rocks pinging off the body (for me at least) was getting mud guards. The running boards don't even help. They would just collect the rocks/pebbles.
Bschurr
NY
Wow - that’s crazy expensive!
On my 21 Badlands, I simply made some rocker stripes using 3M vinyl to match my hockey stick.
Ford Bronco rocker body appearance kit from Ford IMG_4232
ptgptg
peter
Long Island
What light bar is that and do you like it? Does it create a lot of wind noise?
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
I had a lot of chips and marks before I installed the Rock Rails. I was going to install body molding/pinch weld covers although I got the Rails for a 4 door on FB Marketplace for $100, cut them to fit my 2 door. They helped immensely and look so good too.
Bschurr
NY
That’s the M&R 40” bar - worked great and very little noise.
helifino16
Ron
Mount Sinai, NY (Long Island)
I have something similar from Ford - stuck on rocker panel covers. I like the look, but I’ve always had them so I’m not sure what improvement they provide. I used my points so they really cost me nothing. If I had it to do over, I’m not sure I’d go this way. I’d probably just use some bed liner or undercoating.
