Rock rails/Steps - current ones aren't good enough
theblackangus
Right in the middle
25 Badlands, 2020 Corvette, 2011 BMW 1M
Before my Bronco was a week old, I installed the Barricade Open Trail HD Running Boards. I have bounced off rocks many times and they are very strong. They are scratched, but not bent.
That Devils Tower back there?
Rivers90
Ben
Southern California
2 Door Base Sasquatch
These steps came on my 2 door when I bought it and don't have any branding. (I found them via google photo search and they're junk from BuiltRough on Amazon. My fault for not researching and replacing prior to using)
Last trip out they bent right into the body so I want something with better protection/clearance & preferably some sort of step (sasquatch and lifting 2" + 37's).
There are so many options, who have you used that's really held up?
Did these attach to the pinch weld or to the side step mounts? Could you get a photo of the bent part from more under the bronco looking up?
Did the mount fail or was it just the slider itself that bent up?
Astronaut
New Mexico
2017 RAM Longhorn Limited, 2024 Ford Bronco
That’s Cabezon Peak in New Mexico. It’s a lot larger than Devil’s Tower and rises 1600 feet above the surrounding landscape.
Rivers90
Ben
Southern California
Could you take a photo of how they mount o the bracket under the truck?
Astronaut
New Mexico
I won’t have time for photos for a few days, but they easily mount in the Ford factory holes for their steps and rock slider. That reminds me, I need to sell the factory rock sliders that came on my Black Diamond SAS.
Wyld2dr
Wyld2dr
2023 2 dr Bronco; 2016 Audi A7 tdi
Frame with a single bolt, bracket might have bent slightly, step/rail failed completely.
Ford Bronco Rock rails/Steps - current ones aren't good enough PXL_20251104_003554443.MP
Ford Bronco Rock rails/Steps - current ones aren't good enough PXL_20251104_003604926.MP
Wyld2dr
Wyld2dr
Thank you.
I would have thought the bracket was the weak link, but no it was not. Very interesting.
I didn't hit it that hard. Just garbage quality.
NC_Oak
2024 4 door 2.3 sasq
That also prevents that whole rock "sliding" element. Should be clear to all that a straight underside helps from getting hung up.
crenca
Southern New Mexico
Very cool
New Mexico is a hidden gem as far as off-roading compared to say Colorado or Utah. Our club has encouraged our local politicians to at least be cognizant of this, but to little effect. politically, demographically, and in other ways we’re really just a dysfunctional county of Texas. :wink:
Astronaut
New Mexico
Here’s a profile view so you can see that the Barricade Open Trail HD Running Boards cover the pinch welds pretty well…
Ford Bronco Rock rails/Steps - current ones aren't good enough IMG_9286
Valhalla
Valhalla
Chattanooga Tn
They look awful low.
BroncoA51
Jake
Henderson, NV
2022 Bronco
I can attest that the MetalTech 4x4 sliders are beefy. Dropped the weight of the Bronco on them and only a scuff. I got the Sidewinders.
Ford Bronco Rock rails/Steps - current ones aren't good enough IMG_4454
Ford Bronco Rock rails/Steps - current ones aren't good enough IMG_4455
