Reverse takes a while to engage after siting for a long time
Jfman
jean
Canada
Accord
Hello all,
I noticed that if my bronco sits for more than 4-5 days, when I start it and put it in reverse, it takes a while for the gear to fully engage. Like as if reverse is slipping.
Is this a common quirk on these transmissions?
I am thinking it’s probably the oil completely draining out of the transmission and needs a few seconds to refills and repressurize the whole thing.
F-Spot
SoCal
Tesla, FJ
Mine has been doing that lately. It makes a loud clunk going from Park to Reverse on initial startup. It only does it from a cold start on the first drive after a day or so of being parked.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Hello all,
How many miles? Have you had the transmission fluid changed at all?
snolen
stan
indiana
78 bronco
Mine seem to do this only when it's cold and i put it in reverse right away notice it most backing out of the garage mine has always been like that
24GTBadlands
IL
24 Badlands v6 (3 inch lift), 24 S650 with PP GT (pre-production), 1971 Mach1
In older cars it was usually a sign of low fluid, as the convertor would drain down after sitting, and it would take a few seconds to pump what fluid there was up to where it needed to go.
These days could be lots of things.
Nibroc99
Corbin
Rochester, MA, USA
40k kms or 25k miles
original fluid
Definitely shouldn't need a fluid exchange then, can rule out low fluid most likely
bendona
Ohio
Hello all,
Because the torque converter drains back into the pan after sitting a few days, it takes a few seconds for the pump to refill and repressurize the system. Waiting 5–10 seconds after a cold start before shifting into gear will resolve the issue.
However, if it clunks hard or takes more than 10 seconds, have your dealer check the fluid level. There is also a TSB 23-2352 that addresses this exact quirk, which they can fix with a quick powertrain control module (PCM) update.
