Reverse light upgrade?
VirginiaHeritage
Frank
‘25 Bronco HE
I’m finding the reverse light brightness pretty inadequate for backing into my gravel driveway at night, and with a weird arc pattern on the ground as viewed on the backup camera. It’s noticeably dimmer than my other vehicles. Anyone upgraded theirs or added a separate rear pointed flood as an accessory for this reason?
EDIT: nevermind, just found a thread on this
B22-2023
Houston
You’ll hopefully find out about lots of add-on lighting pods. Well anyway not often mentioned is that this Diode Dynamics light is easy if you have a trailer package harness, I’m using it on 2 vehicles. They sell it everywhere including Amazon. There are also tons of cheaper options there like this if you don‘t want name brand, I’ve used on other trucks.
VirginiaHeritage
VirginiaHeritage
Frank
‘25 Bronco HE
…this Diode Dynamics light is easy if you have a trailer package harness, I’m using it on 2 vehicles.
I did get the dealer-installed Ford tow receiver and that sounds like a very appealing mount option. Thanks!
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I have these. They are bright ! https://www.4x4truckleds.com/2021-f...t-w-baja-designs-lights-kr-off-road-brackets/
Diller
Russ
89 F250, 2012 Fiesta
I added two KC Flex Era 1 pods to my roof rack. Very happy with them. You set them up as flood or spot, as well as amber.
Ford Bronco Reverse light upgrade? 20250112_171117
Ford Bronco Reverse light upgrade? 20250112_171105
shadowfax
Central Coast California
VirginiaHeritage
VirginiaHeritage
Frank
‘25 Bronco HE
Shadowfax is a great name for a white Bronco!
Emilian
Emilian
Bucks County, PA
Badlands, Mercedes, Mini
I got R
I got 2021 - 2024 Ford Bronco Rigid SRL Rear Light Kit
https://specialtyperformanceparts.c...bronco-rigid-srl-rear-light-kit-no-drill-sr-l
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Check out some of our reverse kits. They bolt right on and there is NO CUTTING involved. Our included harness just plugs in-line with your tail lights (no need to even remove the tail lights, real easy)
https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/other-lights-accessories/
OffRoadUSA.com
Andrea
Central TX
offroadusa.com
2023 Bronco
VirginiaHeritage
VirginiaHeritage
Frank
‘25 Bronco HE
I’m leaning heavily towards the DD hitch mount light. It seems like the most protected and low profile mount possible. Can’t get dicked up by gravel from the tires which I shed every day coming off my driveway. Won’t clash with my white spare on the back. I just want basic reverse and don’t need the strobe brake version.
Speaking of the spare, I got tired of waiting for Advanced Wheel Locks to come back in stock in chrome so I used my Ford Pass points to order the Ford OEM wheel lock set for now. Gonna put 3 on the spare and nowhere else. If the Advanced version ever comes back in stock before my truck is an antique, I might upgrade. Granted it’s only been 3 weeks but I’m impatient. I want at least some appearance of security back there for parking at trailheads, etc.
LizLambert
Everglades
Liz
Crown Point, IN
Ford F250, Jeep Wrangler 392
Everglades
HI Frank, I am so sorry that the lugs took so long to come back in stock. We use the same plater that the OEM's do, so as a small mom and pop, our pallet of parts gets pushed behind their semi full. This sometimes means that we have to wait weeks to get them. They are back in stock now. Again, I apologize for the delay and the inconvenience that it caused you. We are a team of 4 people vs a multimillion dollar corporation.
