Rev Matching Without Ford Performance Tune?
fuesting
T H E S T E E L C I T Y
2022 Ford Bronco Badlands
Hello,
I really would like to get rev matching on my 2022 4-Door Badlands with 7MT. I really really want to keep the use of 87 octane gas. I'm not sure these two things can coexist by way of a known method.
- My understanding is the Ford Performance Tune is the only way to get rev matching for the 7MT.
- My understanding is that the Ford Performance Tune has to have the increased power tune applied thus requiring 91/93 octane fuel.
Is there a way to accomplish what I want (easily and under $1000)? I really hope there is.
Thank you in advance for the advice.
CarmeloS
Carmelo
Central Jersey
Hello,
Ford Bronco Rev Matching Without Ford Performance Tune? 1719863968876-hn
Order a tune from Lethal and use 93 until you hit your $1000 threshold and then go back to regular?
@lethaljake , tune adjusts for 87, right?
GI_Jo_Nathan
Jonathan
To my knowledge there isn't currently another way to get "Auto" Rev matching, but you can run whatever octane you like with the ProCal. The Bronco has sensors and will just reduce the timing/horsepower.
fuesting
fuesting
I would like this to be true but all my research points to this not being the case. Happen to know of any documentation that would state that? I actually just watched a buckle up buttercup video that stated the engine would have severe issues on 87.
CarmeloS
Carmelo
Central Jersey
Why not run 93? Adds 60+hp with the tune over 87 (330 vs 270)
So. The tune will run with 87 octane. But you should not do that.
I know a lot of people have had good luck - no ill effects, it works just fine.
But…
I think you are rolling the dice doing that. Under the normal tuning (factory not ProCal) the engine starts out being very conservative and will ramp up the timing until it starts to detect any knock. This is how running higher octane can get you a bit of a boost even without ProCal
With ProCal in place though - the engine assumes you have at least 91 octane and starts off with much more aggressive timing and it allows higher boost values from the turbo. This is how ProCal gets the rest of that hp/torque boost. If you aren’t running that, it will knock, and the engine will detune to compensate - but it’s going to be knocking the entire time it’s doing that.
One tank of low octane gas - low odds anything will get damaged. Over time and several tanks of gas - something is probably doing to die a premature death. Especially if you lean heavy into high boost
amazingjason
Jason
CA
1987 Samurai, 1966 442
The ford performance tune is great. The power is great. The auto rev matching is great. Not having to turn off auto stop start is great.
If you can’t afford premium gas, enjoy your Bronco as is. If you can afford premium gas, enjoy the benefits of the tune.
I kind of think you shouldn’t have an inefficient, expensive, somewhat impractical vehicle if you can’t afford premium gas.
Jason
fuesting
fuesting
For my part, my Bronco wasn't expensive, I paid cash for it, and it's not the vehicle I'd buy to hot rod around in. I know some people like having more power and that's cool, but it's not my thing.
This is exactly the correct logic, from my perspective. Plenty of other cars to modify. I simply like rev matching and wouldn't mind paying for the feature on its own. Maybe someday.
fuesting
fuesting
But…
Thank you for the break down of how the tune works. I didn't understand those details and you made it make perfect sense. Frankly, I would give up HP for longevity. I'm fine putzing around rowing gears and going offroad frequently.
