Retune with Ford ProCal Tune
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
I was curious if you should retune the Bronco with the ProCal tune as I tuned my Bronco wirh the ProCal tune before I added an intercooler, muffler delete, and a cold air intake. I know it won't hurt anything to retune it bit was curious if I would benefit from if or if it isn't necessary.
Ducati1098
You can do it, but It wont make a single difference at all.
Ninjak
Miami
IC helps keep your temps down, which will result in better engine performance.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
I have one installed I was just curious if I installed it after the tune if retuning it would make a difference with the Ford ProCal Tune
Ninjak
Miami
@2021FordBronco2 : As Ducati098 stated, the retune will not make a difference because your tune was not built around it. The engine will take into account air temps, ect, and set timing accordingly. By adding your IC, the ECU will allow more timing as the engine temps go lower. I may not be explaining it all correctly, as some others here are, but that is the gist of it.
I have a full custom tune, and I added my IC as well after. Now I did tell the tuner I would have the IC along with the charge pipes, CAI, down pipes ect.
2021FordBronco2
2021FordBronco2
Jo
Nampa, ID
This is what I thought but I wasn't sure, thank you!
ProCal is a one-size-fits-all mild tune. Nothing to configure or change on it
