Replacing 35s with 37s on Sasquatch!
rdmartin01
Richard
Jeep Gladiator Launch Edition
Hey just joined and I even though I don't find stuff in search, I'm sure this has been discussed. Can I just replace 35s with 37s on Sasquatch package? I'm going 37s for sure and if that's not the case, it reduces the value of that option and I just may go without Sasquatch and figure it out myself after delivery.
I got a gladiator launch edition last summer and replaced 33s with 37s using same wheel with no lift and no rub at all. Hoping I can replicate that from 35s on Bronco.
Gamecock
My bet: no chance. It will rub on tight turns at the very minimum...and the 35s don’t really have much room. The 37s would also look ridiculous with no additional lift and almost no gap.
bpurtz
Bryce
Oregon
JKU Rubi, Sierra Denali, Taco TRD Pro, 4Run LTD
37" will fit the Sasquatch wheels, but rubbing is likely. I'm planning the same tire size but will likely use a 2" puck spacer.
rdmartin01
Richard
You're probably right, when I look at it again. So with that in mind, is the consensus to go with no SQ or SQ and add spacers?
rdmartin01
Richard
So add the spacers to the SQ package?
1975U15
2019 F-350 SD, 1975 Bronco
Love look of 37”s, but you’re gonna rub would be my guess.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
https://www.bronco6g.com/forum/thre...rms-fox-shocks-eibach-springs-37-tires.11835/
Ford Bronco Replacing 35s with 37s on Sasquatch! D9DA34AF-6064-4F54-BE49-C7992DBD4A3B
rdmartin01
Richard
Ford Bronco Replacing 35s with 37s on Sasquatch! Screenshot 2021-01-30 at 12.40.22 AM
So many possibilities, Who launches this many models/options at once? I need to lock this down....
HoosierDaddy
__ Eric
NW. Indiana
Ford already did that with one of the early pre-production models, it needed a 2" lift. You can see it on their Bronco page. Look for the header "custom prototypes with aftermarket accesories".
It had the sweetest interior also, that NOBODY can get, even though some of them SUCK!
Ford Bronco Replacing 35s with 37s on Sasquatch! 1611991354088
