Replacing 2.7 crossmember bolts
Nacl_Wander
Lee
Sacramento
Subaru Crosstrek
I’ve purchased a skid plate that utilizes the factory bolts for the transmission crossmembers (mine have been getting pretty banged up)
torque spec appears to be 77 lb/ft however there is a notation saying to replace the nuts? Anyone have experience with this, and is this truly needed?
flip
Phil
IN
www.ruxerparts.com
Fords
Not understanding which bolts/nuts exactly.
One of these?
Ford Bronco Replacing 2.7 crossmember bolts 1715274680667-hl
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
According to Ford and other manufacturers most nuts and bolts are one time use. Me personally I reuse them just double check after a few hundred miles they are still tight.
Baja Bronco
2Sun AZ
I believe you’re describing Nylocks nuts. “Technically” they’re correct, the bolt cuts the nylon insert, which helps to hold or lock it in place.
Saying that, I have reused nylocks. Sometimes you gotta do what you gotta do.
