Removing Sasquatch fender badge problem
userdude
Denton, TX
2023 2dr Badsquatch
It's a black Bronco so I hard to get a good picture without it reflexing the other Bronco need to it, but as you can see in this picture. there is a edge of either clearcoat, ceramic coating that is higher then and area where the decal was when the decal is removed. Buffed it lightly with some compound and also rubbed it done with alcohol. Still no deference. it's 2023 Black Bronco. I'm guessing it a ceramic coating.
Maybe it's a portal??
Ford Bronco Removing Sasquatch fender badge problem 1745272136224-jf
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Some of my thoughts are.....did you buy it used? if so maybe it has PPF on the fender and they used a kit to cut around the badge. My other thought was a crappy body shop painted the fender and masked off the badge instead of removing it.
5GENIDN
Idaho
Question about removing fender badges. Just bought my son a 2023 big band Sasquatch. He wants to remove the fender badge and just put the Bronco script on there. I took the fender badge off and there seem to be an indention in the paint where it goes on the body. Almost like there’s an extra coat of clear coat on the fender and when you take the badge off it leaves a little ridge the shape of the badge? Has anybody else run into this?
That appears to be a little ridge of adhesive.... Happens all the time. Expansion and contraction pushes a little bit of adhesive out from under the decal, the adhesive is clear..... Use isopropyl alcohol (or denatured if you have a quality brand you trust) and a little elbow grease... It will come off just fine.... I do this for a living. I see it all the time.
userdude
Denton, TX
2023 2dr Badsquatch
Where do you buy your elbow grease? Asking for a friend... :whistle:
JimmyZ
JimmyZ
Dawsonville, Ga. 30534
Bronco 2023
OK, I have an updated with the answer. the Bronco we bought was wrapped with a glossy clear wrap. Like some type of paint protection film. It's on the doors, hood, front fenders and rear quarter panels. Not on tailgate or top. I when I wasn't crazy. I've removed emblems before. What they did was cut out the clear film around the fender emblems. So, when I took the emblems off you could see where they were.
Ford Bronco Removing Sasquatch fender badge problem black
Texas_Bronc
Jefe
Magnolia, TX
2024 Ram 2500 Power Wagon / Buying: 2025 Ford Bronco Badlands SAS 4dr
This maybe?
https://www.ford.com/product/paint-protection-film-kit-p2967039004
5GENIDN
Idaho
Well... glad you have the PPF.... Xpel wanted $8000 to do my entire Bronco and I have a two door... SO... BONUS?
Curtis
Stamford, CT
Bronco Outerbanks
Looks like the last post of this thread was a while back but I am experiencing the same issue. OP @JimmyZ what was the end result of this?
Curtis
Stamford, CT
Bronco Outerbanks
What was the solution? Did you have the same issue on both sides? I removed one badge with no issue but ran into this prob with the other side.
Noco
Maryville TN
Toyota FJ Cruiser, Trail Teams edition
it might be clear PPF cut around the fender badge. Raise the hood and look for a wrapped edge of PPF.
