Removing Manual Shift Knob
Lifeliberty
Moonbeam👀
Columbus, OH
CarmeloS
Carmelo
Central Jersey
ToddGreen
Seattle
Ford Bronco 2022
I like it. Not sure I love it. Here are a few observations for for my first drive with the new knob:
Pros:
1) Looks good. It looks like it belongs in the vehicle.
2) Shifts better. I think that the added weight of the knob makes shifting between gears smoother. It's not a huge change, but enough to be noticeable.
3) Size/shape feels good. It's a smaller size than OEM and I wasn't sure if I'd like that. I had ordered the "Chisel" from Archetype cause it seemed like it was a closer matching shape to OEM, but the rounded Boomba has a good feel.
4) Metal wasn't too cold. I park in a garage, so maybe not a great test of temperature, but It was 20 degrees this morning and the knob didn't get too cold.
Cons:
1) Shift pattern (plug) sits a little higher on the knob than I'd like. It's not a deal breaker, but I feel like it was designed like this so that it can be removed, but aesthetically, I feel like it should be recessed a bit more and a smoother feel between the two parts.
2) It's not very unique looking. I really wish Boomba offered some variations in color. Even if it was as simple as the shift pattern plug or the Boomba lettering at the bottom.
3) At the bottom of the shift knob, near the reverse lock, the knob is not as smooth as I'd like. I think this edge could have been more rounded for a better feel. Not a big deal, but was different from what I recall on the OEM. Maybe this will grow on me?
Overall, the upgrade was worth it. I ordered mine using their 15% off black Friday deal, so for $80, it was worth it.
For those of you who have the Boomba knob, I'd appreciate it if you'd be willing to measure it and let me know what the height and width/diameter of the knob are.
I sent a message to Boomba asking this question, and they replied (oddly) in general terms without providing the specific specs.
I'm deciding between Boomba/Twisted/White Madness, and I'd like to compare the size specs as part of that.
Thanks to anyone willing to do this.
Lifeliberty
Moonbeam👀
Columbus, OH
Just under 2"diameter
2.24" height
Ford Bronco Removing Manual Shift Knob 20241224_161149
Ford Bronco Removing Manual Shift Knob 20241224_161057
The twisted shifter (~pool ball size) is larger and feels great
Buy both, or all 3
ToddGreen
Seattle
Ford Bronco 2022
2.24" height
Buy both, or all 3
Thanks a lot for this!
Interesting that you think the TS round knob feels bigger. According to TS' email response to me, their round knob is 2" high and 2: in diameter. But perhaps it feels bigger in the palm.
Is your TS knob aluminum on the exterior? If so, how does it feel in the cold weather as compared to the Delrin exterior of the Boomba knob?
WoolyBugger
MS
Honda Ridgeline / 2dr. Base 7 spd. EG
I have one of each. I like the TS better for some reason but it is cold. The Boomba is not metal so its pretty much temperature neutral. Both are an improvement over OE.
Lifeliberty
Moonbeam👀
Columbus, OH
Not cold at all, a little softer. Anything metal will be cold.
Got the twisted shifter knob. Looks great in person. Nice size, bigger than the AR, lighter weight, but sits a lot higher which I like
I stand by my comparison here: https://www.bronco6g.com/forum/threads/removing-manual-shift-knob.105479/post-2400322
TXDOZER
Les
El Paso TX
2022 Bronco Basesquatch & 2020 Escalade
Went with the B&M Shifter 18 months back to get more clearance over my Yetis, Stanleys, etc. Also moved to the black Hurst Shifter and custom Redline boot. Love them all. The shifter swap isn't bad until you get the small reusable clip. That was crazy, but was able to save it. The Hurst handle was a challenge until I got a Twisted Shifter adapter. Worked perfectly.
I highly recommend the B&M shifter while you're making the handle change.
Ford Bronco Removing Manual Shift Knob 1737308315135-84
