Removing cowl and windshield wiper arms
Bellime
Keith
2022 Ford Bronco
I am preparing to clean the windshield to apply the protective film and thought I might help someone to understand what needs to be done to remove the cowl at the bottom of the windshield. I want the protective film to start under the cowl.
1) Remove the antenna and two screws on both sides.
Ford Bronco Removing cowl and windshield wiper arms IMG_1663
Ford Bronco Removing cowl and windshield wiper arms IMG_1662
2) Remove the cover and nuts on the wiper arms. Then I used a crescent wrench and slipped it behind the arm, then tapped the bolt head. I tried a wheel puller but the cowling got in the way.
Ford Bronco Removing cowl and windshield wiper arms IMG_1664
3)The front edge of the cowling snaps in and can easily be loosened with a flat tip screwdriver.
Ford Bronco Removing cowl and windshield wiper arms IMG_1661
4) Ford put a central coupling for the washer system. Simply squeeze the connection and pull apart.
Ford Bronco Removing cowl and windshield wiper arms IMG_1660
Ford Bronco Removing cowl and windshield wiper arms IMG_1659
Ford Bronco Removing cowl and windshield wiper arms IMG_1658
5) Lift the cowl out and your done.
Ford Bronco Removing cowl and windshield wiper arms IMG_1655
williamshafer
William Shafer
New Palestine, Indiana
Jeep Rubicon
So it looks like you just have to sort of muscle it off the stud?
Bellime
Bellime
Keith
2022 Ford Bronco
Well, used the crescent wrench as a backing and tapped the stub back. Really no muscle required
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
I’m trying to do this now. Not sure I understand the removal of the wiper arms. They won’t budge
@BadBlueBronco
Kc
Los angeles
Update: I went to Harbor freight and purchased a 2 arm puller. Passenger side had enough clearance but driver side didn't. I was replacing the cowl because it was bent and a POS(scratched my hood) so I didn't mind a small scratch on the plastic so in the end it worked. I think if I had a thinner armed puller it would of worked out better.
Bellime
Bellime
Keith
2022 Ford Bronco
I have had my wiper arms off many times,no puller needed. Just be gentle on tapping the thread post with something behind the arm.
Karl_in_Chicago
Karl
Chicago
Thanks OP for taking the time to document and share! I'm planning on applying a coating and while I don't *need* to remove cowl/wipers to do it, it definitely eases access and makes for less stuff that needs to be taped off. Now I just need to replenish my supply of round tuits. 😜
bniknar
Bri
An old EcoDriver
Which 2 arm puller at Harbor Freight? Appreciate any info.
Lak34ers
Troy
Seattle
I was getting a little rattle wind noise and notice my cowl was pretty loos in middle. If you tapped the top with your hand you can hear it rattle...not tightly clipped down. Looked at my clips in center of cowl and they are smooth with no ridge to clip it down. Yours in pic looks like it has a ridge to catch on the lip and hold it down. Any ideas? Ready to put a heavy weight on it and just glue or seal it somehow.
Car Guy Bill
Homer Georgia
25 Marsh Grey Badlands Sasquatch HOSS 3.0- 2025 Mach e GT Performance Upgrade
The way I always have removed the arms on most vehicles with a nut is to loosen the nut but do not remove it then flip the wiper arm up and rock in the opposite way it bends and after a couple of rocks it will normally pop right off. I would be scared hitting the stud like a tie rod end that close to the glass. This is an old school way from back in the 70s
Bellime
Bellime
Keith
2022 Ford Bronco
That is too permanent, haven’t had it off in a while, but I think your right in your missing the ridges. I’d use something less permanent, like sponge tape. Is there a way to pur a screw from hood edge?
orion
Jeremy
17' F-250, 17' Explorer
Pull your cowl off completely. Use some baking soda and put some where the ridge would be, put super glue on it, then use a file to shape it like it should be. That might work.
sweisenb
scott
virginia
bronco
I agree that is what should work. What I did was soak the threads/arm/splines with penetration oil (NOT WD40, Deep Creep and PB Blaster) and let it soak a a while. I ordered these pullers from amazon (https://www.amazon.com/dp/B0BXLMGYWB?ref=ppx_yo2ov_dt_b_fed_asin_title). I used the two arm puller to tension the arm and rocked back and forth. One of them came off with ease the other required a 2nd soaking.
CalvinT
Calvin
Phoenix, AZ
