Recovery gear for sand/beach driving
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
That's pretty much what's on the list.
Any all in one kit works (my main question)? If not, I'll just get the things separately.
I'm guessing either below link or just some plywood would work ok for a jack support?
https://www.amazon.com/Garfatol-Bui...TnsDbhQMVFk5HAR0z3A_9EAQYBSABEgL5yfD_BwE&th=1
These are 'they':
https://www.outerbanks.org/plan-your-trip/beaches/driving-on-the-beach/
https://www.nps.gov/asis/planyourvisit/osv.htm
My question is whether anyone has ever seen/found an all in one type kit I could get or whether I should just get the components separately.
I'm finding some gauges and certain kits bundled with a tire repair kit. Is a tire repair kit worth it or fairly unnecessary?
Ya'll fergot Sikorsky S-64...
Ford Bronco Recovery gear for sand/beach driving sikorsky_S-64
CalvinT
Calvin
2002 Subaru WRX Wagon, 2023 Badlands
SmallCrawler
2023 2dr Bronco
Not beach specific, but when you start traveling off the beaten path consider adding a breaker bar and deep socket so you can easily change a tire. Stock lug wrenches are sometimes difficult to use after getting your tires rotated where the junior lube tech over torqued the lug nuts. A pair of mechanics gloves will also help those who don’t normally work with their hands.
CalvinT
Calvin
Don't need a breaker bar. I carry a 20V 3/8" impact driver. I used to carry a large 4 way lug wrench. Impact driver will loosen lugs after you've jacked it up. Gloves are highly recommended. And something to lay on.
OBXBRONCO
mike
Bath NC
2023 Bronco Wildtrak
Been driving obx beaches for 40+ years. my recovery gear consists of tow strap, shackels, Pretty thick bait cutting board as a base and a bottle jack, Shovel. Also have ARB on board air compressor and a winch. Never used any of it on myself except the the air compressor.
Dral97
Dral97
Ford Bronco, Wrangler YJ and 392, BMW 4 series
Ford Bronco Recovery gear for sand/beach driving 20240420_111044
Love it. I'll be looking for your Bronco when I'm there!.
Thanks everyone for the info in the thread. I found a kit or two I like. I'll likely get one of those and then supplement with the other things in this thread that people mentioned.
