Rear window support
Rayz Garage
Rayz Garage
Ray
Warrington , pa
2023 Bronco
The wiper motor rests on the spare and I would only do it on the open road
ChrisB351
Shreveport, LA
Better to drive with it all the way open. I do it all the time around town. If im gonna be on the interstate at 70 for more than a couple miles Ill close it.
AK SNO RIDER
Ty
Alaska
Looks like you're putting force on a cut out in the middle of the glass, and seeing as several people here have had their rear windows spontaneously explode, I'd pass...
Mlarv
TN
I would use a strut clamp to hold it open. If you want it partially open, just clamp it then use your bungee cord to hold it down.
Strut Clamp
Imonamoose
Moose
Earth
Truck
Strut Clamp
Nice! Didn't know about these. Thank you.
Aonarch
Jack Hoff
MT
Bad idea.
Mlarv
TN
I have used these on hoods or trunks when the struts start to go bad. I might try it on my rear window to see how it works out. I will use one on each strut to make sure it is not uneven.
Imonamoose
Moose
Earth
Truck
I wish there was an easy way to remove all the clam shell hard top windows, side and back. Safari top should have been a built in option.
Lifeliberty
Moonbeam👀
Columbus, OH
I would worry about strut separation from mic top
Top isn't designed to be driven like that. For open air it is designed so you can remove the top, anything else is up to fate
