Rear Window Molle Panels
JTBros
Long Island, New York
GR Corolla
jsoa
Jose
Delaware
2024 Bronco 4dr
I went with TOR molle panels, no complaints
Ford Bronco Rear Window Molle Panels PXL_20240328_235123902
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I have the one from Broaddict. Easy to install. Solid quality.
Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
Koss_co
Everglades
2024 Bronco, 2022 F-150
Everglades
Broaddict also.
Ford Bronco Rear Window Molle Panels 1762275991865-9c
JTBros
JTBros
GR Corolla
For those who went with Broaddict, is there a weight limit they state? Turn off road states 40lbs each.
Phil B
Phil
Plano Texas
I'm assuming you are asking how much they weigh? Shipping weight was 16.76 for the windows, 35.2 for the side panels, and 39.8 for the shelf. If you are asking about capacity, I don't believe that is stated. They are stout. I suspect they will hold pretty much whatever fits.
JTBros
JTBros
GR Corolla
GlueBoy
gluefactoryoffroad.com
21 Bronco
JTBros
JTBros
GR Corolla
GlueBoy
21 Bronco
I read through those and saw the inserting of bolts from above which is why I was curious. Good to know that it can stay on for the install.
No problem. If you check on your machine you'll see there's space at the top.
Bad Frog
US Virgin Islands
2025 Bronco
I recommend you check out XG Cargo's M-Panels. I bought a set from their initial run. They are contoured to fit the window area better than some of their competitors. I am very happy with them.
