Rear tubular bumper question.
cbert5
florida
2022 bronco
Hi. Thinking of getting the rough country tubular rear bumper to match the front tubular I have on my bronco 2022. The mechanical mounting doesn’t worry me. But the wiring of the led lights do. Not an electrical wiring fan. Is it a chore to get the wires all the way to the engine compartment to plug into the auxiliary wiring for the aux switches. Or am I bette rod just putting the block off plates in and forget lights all together. Thanks for any help.
Ford Bronco Rear tubular bumper question. IMG_8453
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
I have this bumper and you don’t actually have to wire all the way to the engine compartment. There is a wiring diagram somewhere on the forum, I’m sure if you search aux switches wiring diagram something should come up.
basically you connect the wires from the aux switches in the hood to a wire behind the glove box, then another wire runs to the passenger side of the cargo area, which is where you would connect the rear bumper lights.
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Here is the title of the thread
2021 Bronco AUX Switches Wiring Diagram, Video, Discussions
dgorsett
colorado
F250, Mustang, Explorer
I don't have aux switches. I tapped power at the rear power outlet to get the acc delay to use the lights for reverse and work. Then ran the included switch to the console.
Ford Bronco Rear tubular bumper question. 17429435160938054176221033173319
BTW bumper install is very easy, easier than the front by far. I feared wiring, and blocked the lights out for a few monthes, but finally went for it. The included lights, shackles and license plate relo are a bonus
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Sorry to highjack:
does anyone know if you can mount the license plate bracket to the bumper itself? I don’t like the look of having it on the spare tire.
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Sorry to highjack:
No but you can grab yourself one of these bad boys! I have this because i also didn’t like it blocking my sweet wheels on the spare
Ford Bronco Rear tubular bumper question. IMG_4509
