rear drive line seal
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
Im waiting on a new rear driveline, ive gone through my 2nd upper seal (one where the cv bolts to tcase). This one with less than 20 miles on it the boot tore.
Question is, I have a small vibration at low speeds due to this, but at highway speeds its fine. How long can I safely drive on it, or will it just get worse and worse? Im kind of in a bind and need to go about 300 miles and need to take it, or figure out another way.....
Felix808
SRV CA
How bad is it leaking? Moist no drips? No problem. Leaving puddles? I wouldn't travel far.
Vibration could be a number of things though.
$.02
wyobronco
wyobronco
Clint
Wyoming
$.02
big tear, empty. POS LOL. Im getting a little irked, both drivelines did it and now ford is fighting with me.
Felix808
SRV CA
So its the boot, not the seal in the transfer case. Is it the drive shaft boot? Hard to say, might be a bad CV issue causing the vibrations, really hard to tell without seeing it.
wyobronco
wyobronco
Clint
Wyoming
Ford Bronco rear drive line seal 93CE1FB4-45F6-467B-803C-C5AD1E2091E6
Felix808
SRV CA
I would push the issue of Ford replacing it & not drive it to avoid the "well you shouldn't have driven it like that, so now it caused this or that" response.
I'm thinking there should be more grease in those bearings than I can see. :unsure:
Silver-Bolt
Eureka, MT
Are you at stock height?
wyobronco
wyobronco
Clint
Wyoming
First one was at stock, 2nd one went on after the lift. I had noticed the tear when I put the lift on. Its only a 2" collar lift. That one lasted a few miles.
Aztec1382
Sam
F350
did you end up replacing the driveshaft or do they make a seal you can purchase
just noticed a tear in mine as well
Mark Borgmann
St Louis MO
2022 Bronco
Mine just started leaking at the front boot/seal recently. haven't had any luck finding a replacemen
Ford Bronco rear drive line seal 20231106_221736570_iOS
t boot.
feeble
Shawn
Yankton, SD
2022 Badlands, 1977 Cobra II Monroe Handler
Same issue here. Noticed a grease spot on the rear driver side inner fender liner. Traced it to the boot on the front CV joint of the rear driveshaft into the transfer case. ~12k miles. Never been off road. Stock height, no lift.
Ford Bronco rear drive line seal IMG_2400
Ford Bronco rear drive line seal IMG_2403
feeble
Shawn
Yankton, SD
Had the dealer check mine this morning. Will be replaced under warranty. $1000+ for the part if not under-warranty.
feeble
Shawn
Yankton, SD
That’s 20%+ over retail.
You can get one online for $600
Yep. Just what they told me when asked. I have an extended warranty. Once that is up in 4-ish years, aftermarket support should be that much better.
