REAL Maintenance Schedule
EgreenBadSquatch
Washington
2015 F-150, 2022 Badlands Sasquatch
I’m a fairly decent mechanic. How difficult are the diffs and transfer case to do at home?
SWLABRONCO
SW Louisiana
Ford f150
The front Differential and transfer case are very easy. Both have drain and fill plugs. You just need a 3/8" drive ratchet and short extension for those. The rear differential requires you pulling the cover to drain it. It's an easy job also, and the gasket is reusable. I recommend buying the bags of gear oil/transmission fluid vs the quart bottles. It's quicker and alot less mess.
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
Bingo! Great thread! That thread got me started. All I have left to do is the tranny and PPE pan install prior to my 25K mark. Diffs and T-case are done.
Regardless of "schedule", PLEASE do the oil every 5K! The turbos will toast the oil fast and it is good to do especially if wheeling.
DRC
Cedarpines Park, CA
22 Bronco
I like this idea, but am having trouble finding the severe service maintenance chart. Any idea where I can find it?
Ditto. Anyone hve a copy of the "severe service maintenance chart."
lakesinai
Charleston SC
Hello, everybody. I’m the proud owner of a 2022 Wildtrak that I bought about 9 months ago used. I’m quickly approaching the 50k mileage mark. The maintenance schedule that Ford provides is… optimistic, in my opinion. I should mention I do a decent bit of offroading and towingWhat do y’all think I should REALLY be doing at 50k miles, and how often in general do you think preventative maintenance items should be done?
Here’s what I’m thinking for 50k… let me know if I’m missing anything, or if I’m being overly cautious.
Brakes
Spark plugs
Oil change
Tire rotation
All new fluids
Thanks, y’all!
I'm at 85,000 on my 2021 OBX, and I still have my original disc's and pads. Ford pointed out early on that they made the rotors thicker to compensate for the smaller diameter that the Base wheels required, and all original 6g Broncos have the same brake set on the 4dr. I'll change them when they're ready.
At about 75,000 miles, I followed my dealers advice and did the 6cyl fuel injector cleaning (also highly recommended on the 6cyl ECOBoost on my previous 2016 F150).
Plugs too.
Also did the engine fluid exchanges about 70,000 miles.
Do WORKS (OLF) every 5,000 miles. Air filters every 2-3 oil changes. I've been putting almost 20,000 miles on car yearly, although that has slowed down.
Hammerli22
Isuzu Rodeo
If you don't know how the bronco was maintained by the previous owner,, I would change change everything, o/f , a/f, at filter, frt diff, rear diff, txf case , brake fluid , g/f , cabin filter, check all ball joints, tie rods, cvb boots, everything.
Valhalla
Valhalla
Chattanooga Tn
Honorable mention: If you wheel it may be worth pulling drive shafts and checking the joints for play. You might also, if you wheel hard, pull the front axle nuts off unseat the axles, put a light anti seize on them and paint the mating surface (no threads). Reinstall new axle nuts. Check your tie rods for binding or play as well.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Two questions: Are we buying new gaskets for the rear diff with the stock cover, or are we using RTV usually? I also have a 2022 4dr wildtrak.
Also, are y'all typically doing the transmission fluid at home? Or is it such a hassle/complex that it's worth taking to a reputable mechanic instead?
Hammerli22
Isuzu Rodeo
Reusing old gasket, it's reusable.
Will do a/t fluid my self. The only challenge is filling it up to where it should be @temperature w/o burning your hand, IMHO
I've had my rear cover on and off dozens off times and still on the original factory gasket. It's pretty durable. No RTV required. Just a bit of PTFE tape or dope on the threads of the fill plug is all you need.
Nibroc99
Corbin
Rochester, MA, USA
Glad to hear. Hopefully, having bought the vehicle with 58k mi on it, a previous owner hasn't disposed of the gasket. Based on the condition of the transfer case fluid though, I bet the diff fluids have never been changed.
Likely, it isn't exactly specified early on in the maintenance schedule if you follow the Factory Reqs for normal driving (like 150k or something?)
