Raptor or 25+ Bronco Digital Cluster upgrade???
MachingBird
Christopher
Western, NY
2015 F-150 Lariat
I have a white 24 WildTrak Lux pkg. and am trying to decide which OEM digital instrument cluster to upgrade to. A couple of retailers have plug & play clusters from both the Raptor Bronco and the 25+ Bronco. I don’t want features on the cluster that my WildTrak doesn’t have/support or that I can’t add with Forscan.
That being said, who has done this upgrade? Which cluster did you decide upon and why? What sub-model did you install it on? Can either cluster be programmed to show “my” Bronco (color/trim) in the welcome/start up screen?
Thanks in advance.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Ducati1098
I went with the 25+ cluster. Mainly because I didn’t want raptor graphics on my Wildtrak.
That and it was cheaper and had never been done before at the time.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
hey @Ducati1098
I read on one of your posts (https://www.bronco6g.com/forum/thre...-gauge-display-oem-part-numbers.107277/page-2) post #21
There are only 2 versions of the 25 cluster.......that post was a bit over a year ago. That still hold true?
Looking into the cluster swap and trying to verify if there is a different PN for MT v auto clusters
I have the pn as S2DZ-10849-E
cheers
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
I have the raptor cluster on my 23. I like it but I have never been able to reset the oil life.
Ducati1098
hey @Ducati1098
cheers
Only 1 for regular 25 bronco clusters (except the Braptor, which would make it 2)
But yes, S2DZ-10849-E is the most current part number.
No differences between AT/MT
Alfa
Diego
Austin, TX
Bronco Wildtrak
Did you get it from Panda, or somebody else that has figured out how to integrate it, or did you do the programming yourself?
jayr1959
Jay
Delaware
Yes on the panda and it took 10 weeks from order to delivery. It was programmed with my VIN but required other forscan changes. The programmer was at a show and I was not able to get an appointment. I was able to figure out the issues. I have a two door and its was programmed for a 4 door. I was getting a rear seat belt fault. I used forscan to disable the 3rd seat and that fixed the error. I also updated the milage since they took longer to ship it was lower than what was on my vehicle. That is an easy fix. I did reach out about the oil reset and they have not figured it out yet. I believe it's a known issue.
Alfa
Diego
Austin, TX
Bronco Wildtrak
I think that the oil reset is an issue for people installing the 2025 regular bronco display, but allegedly the foot pedal reset works:
To reset the oil life reminder in a Ford Bronco (2021–2024):
turn the ignition on without starting the engine, then fully press and hold both the brake and accelerator pedals simultaneously for about 25 seconds until a confirmation message appears.
I would be curious to see your IPC configuration to see how different it is from the Raptor as built.
