Random Accessories
RunNGunArk
Brad
Fort Smith, AR
2022 Badlands Sasquatch
Bagziga
Iowa
2015 Focus ST
thanks.. got one recently and works great
What dash cam are you using it with? I've been leaning toward the Garmin 57, at least out of the options Dongar has on their website, but I haven't done much research into other brands or models yet.
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Still debating this as well. Leaning towards the Garmin Tandem, that way I have a view of the cabin when parked and running topless.
RunNGunArk
Brad
Fort Smith, AR
i bought one from BestBuy..their house brand.. one thing it lacks that i'd recommend you ensure you get..APP connectivity.. i'd like to be able to connect to it via an app to review footage, not take out and go inside to plug up and review.. (or remove memory card and take inside). I'll probably replace with a garmin in near future...hopefully there will be some Black Fri sales..
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
I just got the stuff to add the wiring, it’s going to be my Saturday project you don’t have to have trailer lights but you can get a ticket especially at night. Here is what I got to get to the 7 pin plug, I don’t need brakes or backu lights so figured I would go this route
Ford Bronco Random Accessories 2F125518-1351-4D79-86E5-17B53974248D
Ford Bronco Random Accessories 65E14BD1-CDF0-44FA-959E-F1DFA88DD30C
Basssquatch
Felipe
Ca
I haven't done much inside but I'm happy with this little mod. (added USB port, wireless charger, and short cable)
Hey! Did your bronco already come with a center dash USB port ? Or did you install one?
KPLOBX
Kristopher
Savannah GA
Jeep Wrangler TJ
How did you install the USB port?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Gettyup
Rocky
So Cal
Bullitt Mustang, Expedition
Sure would make a nice write up on how you installed the USB port. Curious minds would like to know!!
Tricky Dick
Dick
PNW
There's really not much to write up. I just bought the plug/cable, cut the hole, and fished it down to the USB port in the console. Eventually I want to give it dedicated power. I put the hole in that little piece so I wouldn't ruin my whole dash if I messed up.
Gettyup
Rocky
So Cal
Ok I was wondering how you wired it up. Thanks for the info.
Ground_zero298
Ground_zero298
Scs michigan
Finally found the best phone charger I’ve come across. Wireless charging, motorized grips! Had to upgrade to the ram accessories to get it in a good location. Just ran metal screws into the grab handle. Very sturdy
25mm to 17mm ball adapter. This is the key piece to get normal small ball mounts onto a ram 1” ball mount.
Don’t mind the cord. All I had on hand for tonight.
Charger
https://www.amazon.com/gp/aw/d/B07RBC21Z6?psc=1&ref=ppx_pop_mob_b_asin_title
base mount
https://www.amazon.com/gp/aw/d/B002KO5XVU?psc=1&ref=ppx_pop_mob_b_asin_title
Extension
https://www.amazon.com/gp/aw/d/B005KWPJ04?psc=1&ref=ppx_pop_mob_b_asin_title
Adapter
https://www.amazon.com/gp/aw/d/B01MZXRSST?psc=1&ref=ppx_pop_mob_b_asin_title
Ford Bronco Random Accessories image
Ford Bronco Random Accessories EFD4A032-A78A-4825-BDB3-F8A614DAD018
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
