Random Accessories
SwampCactus
2022 4 Door Cactus Grey Badlands Sasquatch
Assuming you wired this into the fuse box with a fuse tap??
If so, which fuse location did you use? If not, how did you wire it?
Just to the battery. It has a fuse inline on it.
SpringBreak98
Cade
Valdosta, GA
Cruised “bronco accessories” on Amazon night. Got some good stuff.
Aluminum knob covers
https://www.amazon.com/gp/aw/d/B0B3MR1G5K?psc=1&ref=ppx_pop_mob_b_asin_title
Uniden external speaker for the 275
https://www.amazon.com/gp/aw/d/B009TNABQ2?psc=1&ref=ppx_pop_mob_b_asin_title
Sunglass/small item holder for top of visors. Fit good.
https://www.amazon.com/gp/aw/d/B09R1GBYF6?psc=1&ref=ppx_pop_mob_b_asin_title
Center console storage sadle
https://www.amazon.com/gp/aw/d/B09YQ2WX1M?psc=1&ref=ppx_pop_mob_b_asin_title
Descent looking stubby that still gets reception
https://www.amazon.com/gp/aw/d/B09NNJYKP9?psc=1&ref=ppx_pop_mob_b_asin_title
Rock Lights W/remote
https://www.amazon.com/gp/aw/d/B09KG59PMZ?psc=1&ref=ppx_pop_mob_b_asin_title
Jeep light bar the fits damn near perfect on our inside roll bar. Just wired it to the back of the dome light. The 2 outside wires. Yellow + black - pair of t taps will be fine. It does not turn off or on with the dome light and that circuits on the timer when the truck is turned off. Hence the remote to turn it on and off. Currently looking for a spot to tap to make it work with the inside lights
https://www.amazon.com/gp/aw/d/B076KR77Y9?psc=1&ref=ppx_pop_mob_b_asin_title
If you have a light and want to add a remote, these relay fob kits work good.
https://www.amazon.com/gp/aw/d/B09MD63LY6?ref=ppx_pt2_mob_b_prod_image
Tail gate hinge covers in gloss black
https://www.amazon.com/gp/aw/d/B09XTXD327?psc=1&ref=ppx_pop_mob_b_asin_title
First of all, nice rig 🤘 It looks like you have every accessory known to man 🤣
Next, are those the Ford Accessories race red grab handles or after market? And if they're the Ford parts, how well do those knobs match?
RCVBAF
Brett
Caddo Mills TX
2023 Ford F-150 Heritage, Ford Ranger FX4, & 2025 Bronco
Mabett soft top window storage bag-no more wrapping my windows in a blanket.
Mabett Gear Side Storage Box-phone fits perfect
JTops sun shade- no more baking in the Texas sun.
Ground_zero298
Ground_zero298
Scs michigan
The handles I painted with my air brush. Creative colors wicked red seems to be a exact match to race red. Put a dab in the gas tank door to check it. Couldn’t find it the next day. Knobs actually match well. Really happy with them.
Most people start with the big ticket items. I like to work it the other way around. Can keep thinking/adding all the small stuff I want and not run out of money. You get rims and tires, thats all you get for the next 6 months.
SpringBreak98
Cade
Valdosta, GA
Coulda fooled me, they look like the factory set. I had a feeling those knobs wouldn't still be there if they didn't match or looked good. Might have to pick those up when mine gets here. Appreciate it 👍
Ground_zero298
Ground_zero298
Scs michigan
Thise knobs are a steal for $40. Can’t beat $7 a knob. I think stickerfab wanted $14 just for the vinyl goat ring. These aluminum ones are the way to go.
SpringBreak98
Cade
Valdosta, GA
You sold me. Went ahead and picked them up forgot a I had a gift card as well so got them for $16 😎
Maidfh
Hawaii
Bronco Badlands
Stickerfab phone mount
Muslogy interior liners
Muslogy door handle storage box
StickerFab
Fort Myers
www.stickerfab.com
2021 Bronco Badlands / 2023 Bronco Raptor
Anyone know of anywhere with the DONGAR dash cam power adapter in stock? Dongar is out of stock and so is @StickerFab . cant find anyone else selling them.
Back in stock. I know it's been a while. 100 here, but boy do they fly.
Ground_zero298
Ground_zero298
Scs michigan
Cmccmc
Massachusetts
Explorer
Don't throw out the factory license plate holder! With the a little trim work it works with the plastic bumper and skid plate.
Did you just screw right into the plastic skid plate? Seems solid? I'm driving around with the front plate on my dash until I can figure out a solution.
Bemcnamara
Brad
Coeur d'Alene Idaho
2015 F56S MINI
Yes, it is very solid. I used a Dremel too and trimmed the plastic plate holder so that it fit flush then screwed it to the skid plate. I then put a bead of black extra strength silicone to the sides to take care of any unevenness. (I first verified that there was nothing behind the skid plate.)
EgreenBadSquatch
Washington
2015 F-150, 2022 Badlands Sasquatch
I like these rock lights. Would love more info on them. Are they really wireless? Where did you mount the controller? The extra on/off switch seems unnecessary did you use it?
Ground_zero298
Ground_zero298
Scs michigan
Had no issues with them at all. Been running them when out and about to look for gremlins. Yes they are wireless, no control box at all. Think it’s built in the lights? Very bright lights. They rolled the edges so some light comes out the sides like a surround instead of straight down. The lights them selves have to be hooked together and then to the battery off the supplies harness. The remote can go anywhere, has to be plugged in. But has no physical connection to the harness.
I mounted the remote in the center arm console. I left the switch attached, just left it in the on position and put it under the steering column. Remote has a cig plug on the end of it, maybe 12” long. So instead of the normal cut and splice I just used the port in the armrest.
I had wired them to a lifter switch. So I can turn the power on with that, then activate/pick colors from the remote. Remote has a color led in it. As you cycle it changes on the remote as the lights change. It does not have amber setting.
Very nice kit. No issues with rain, rocks or anything yet. I looked at Baja and diode but I know most their moneys tied up in lens design. Couldn’t justify $400 a wheel well compared to these.
Ford Bronco Random Accessories 22DE19D7-6AAF-4BA0-83D5-E3A44A4A4129
