Ram Rail Mount -- anyone using one?
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Anyone using the Ram Rail mount? Was considering it to mount my GoPro, phone and Garmin Tread Overland.
EOSeabee
Patrick
Las Vegas
2022 Ford Bronco 4 Door Badlands
I got the Archetype Racing one and it's great. I use it mostly for a GoPro. I had my phone mounted as well, but it was just too much in the way. I have a Garmin Overland as well, and it was too big for the dash IMO. I ended up getting the Archetype grab handle and a Ram Mount and that's where it rides.
Ford Bronco Ram Rail Mount -- anyone using one? IMG_0674
BroncoDymond88
New Jersey
'23 Bronco
I have the D also, but I think he’s looking for the rail that goes on the dash. I have the one from AR and couldn’t be happier. It looks stock and I’ve mounted cameras to it for road trip Timelapses
Callelk
Callelk
Larry
Idaho
Yep, this one,
Ford Bronco Ram Rail Mount -- anyone using one? 1699204956601
With the 2" ball and arm I'm thinking it would be at a comfortable level.
Though I am wondering how they got the hero switches reversed..............
BroncoDymond88
New Jersey
'23 Bronco
Personally I think the AR version looks way better but it's your preference!
Callelk
Callelk
Larry
Idaho
I like how the Ram rail uses the vents for support without drilling etc. I called Ram engineering and asked about a 2+# Overland GPS and they tested it with 5# suspended 90 degrees without issue. Function over Form and what, 1/5 the cost.
Callelk
Callelk
Larry
Idaho
You have the 8"? What length arm did you use or did you stick with the OEM Garmin and 2" ball size or go down to 1"? Would like to see a picture of it mounted.
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
I have the Ram Rail Mount, and it works great even holding my ipad pro in place. I was the one that got Ram to develop this Rail, and make it stronger than the rest, without any drilling. You won't be disappointed with this Rail. Don't have any pics at the moment, but will be doing a complete coverage video and pics soon. I also have the bracket that mounts to the front of the passenger seat that I mount my laptop too. With both, I have multiple screens, and passenger can still sit in comfort. If you have ever done any Rallying, you would know that more information is critical in that situation.
EOSeabee
Patrick
Las Vegas
1” ball and 6” arm.
6” arm and 1” ball. Trying to upload some pics but the files are too big. 😡 I’ll figure it out and get some pics on here.
Callelk
Callelk
Larry
Idaho
Thanks for the photo. The Garmin weighs twice as much as the iPad so I'm not sure a 1" would work but I do like that arm.....a lot more articulated than the standard.
EOSeabee
Patrick
Las Vegas
It’s pretty solid. It holds my Garmin perfectly. I used the 1” ball because it fit the grab handle threads.
Callelk
Callelk
Larry
Idaho
And you have the 8" Overland?
Callelk
Callelk
Larry
Idaho
Okay, thank you for the info.
Doesn't Ram have a C size ball with 1/4-20 stud? Just thinking out loud here, the base diameter may be too big for the "D" handle.
