Ram Rail Mount -- anyone using one?
Bruzer22
CO
1968 Mustang, 2022 Bronco
Anyone using the Ram Rail mount? Was considering it to mount my GoPro, phone and Garmin Tread Overland.
I had the rail, returned it. my phone bounced and jittered all over the place. The only way this would have been solid is if it was drilled/mounted.
I didn't need a full length rail, so I ended up going with the Archetype SLAP mount.
EOSeabee
Patrick
Las Vegas
2022 Ford Bronco 4 Door Badlands
1” ball and 6” arm.
6” arm and 1” ball. Trying to upload some pics but the files are too big. 😡 I’ll figure it out and get some pics on here.
Ford Bronco Ram Rail Mount -- anyone using one? image0
Callelk
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Okay, I see you have the Overlander, I have the Tread Overland which is 1" taller, 2" wider and weighs 1/2# more. Not much but can make a difference.
EOSeabee
Patrick
Las Vegas
I think you’d be good to go with the exact setup I’m using. Like I said, it’s rock solid.
Callelk
Callelk
Larry
Idaho
I'm going to try it. If nothing else I can use 3M tape on the grips for the defrost vents and the feet. Holes can't be reversed and glue can be cleaned. Additionally, I do not have the lux pkg so I have to go with the IAG power point and it looks like the plastic of the RAM mount can be removed to expose the std USB port.
Callelk
Callelk
Larry
Idaho
I may decide to but I still need the rail for GoPro, iPhone and almost forgot, Garmin 200i.
Ford Bronco Ram Rail Mount -- anyone using one? 1699290298538
EOSeabee
Patrick
Las Vegas
I just bought the Tread. A lot more features than the Overlander. I see what you mean about the Tread being heaver. I set it up exactly the same as the Overlander and it is still rock solid. 1" balls work great.
5GENIDN
Joe
Idaho
Yep, this one,
With the 2" ball and arm I'm thinking it would be at a comfortable level.
Though I am wondering how they got the hero switches reversed..............
Surprised no one answered this.... The hero switches appear reversed because if you notice to the right... the start button and the steering column... right hand drive.... OR at least that is what I thought... until you zoom in and see that all the text on the screen and start button are mirrored as well... Photoshop mirrored image. They used it to highlight the product and I guess the graphic artist liked the lower left to upper right view better.... so rather than taking another pic... they just mirrored it.
Callelk
Callelk
Larry
Idaho
Australian model Bronco :)
5GENIDN
Joe
Idaho
I knew they were the "land down under" and since the earth is flat they have to walk on their hands... but I did not know they use "mirrored text".... Cool, learn something new every day!😆
