Radio not working
Zus
Atlanta
82 & 22 Bronco, 17 F150, 12 Expedition
How many people have run into this issue. My 16 Mustang would do this randomly also. What was your fix? It just doesn't even power up. Usually a key cycle after driving is my fix.
Ford Bronco Radio not working IMG_20231231_113110927_HDR
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Press and hold the power & Fast forward button for about 5 seconds. Otherwise pull the negative battery terminal for 5 minutes.
If neither of those work/help, a visit to the dealer
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Have you recently had an OTA update? Mine did this a few times after one had recently occurred. I did the reset that was recommended by @Boreal but ultimately it corrected itself in a day or so. I never did disconnect the battery to try that method though.
It should still be under warranty, so worst case scenario I’d take it in to the dealership to be looked at.
Cletus
Washington
23 Heritage, 92 Mustang GT vert, 67 Mustang coupe
I had the same experience recently, whether the radio not working, the screen freezing mid-animation, or briefly remaining black, and also suspected it was OTA-related. All were only briefly, and resolved on their own, or after the next powercycle.
PrepVet
North Central WI
A bunch.
Happened to me as well but it was tied to the driver aids and dash going out as well. The car was in the shop for only a couple weeks, it didn’t need anything back ordered which was fortunate.
604Bronco
British Columbia
www.bronco6g.com
Did they say what the issue was/what needed to be replaced?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
  • Like
Reactions: Zus
PrepVet
North Central WI
A bunch.
I don't fully recall, I'll see if I can find the paperwork. I do know some of it was a "software update" whatever that actually means or was done, but there was also a "wire harness" that needed to be replaced.
CarmeloS
Carmelo
Central Jersey
It aint just me huh? Find putting it in reverse and back fixes it
Discusman68
Travis Bates
Ohio
2022 Bronco outer banks
Mine just did this tonight so I came here to see what to do. The power fast forward thing didn’t work. Disconnected the negative and will get back asap.
