Questions about upgrading to modular bumper
25BroncoGuy
2025 Bronco Base
Hello,
Been wanting to upgrade my front bumper from the basic plastic one to the OEM modular bumper and had questions.
1. Is it possible to upgrade it?
2. Is it easy to do it myself?
3. How much does it cost?
4. Can you provide link(s) to purchase?
I have:
2025 Base Bronco w/ Sasquatch Package.
No parking sensors or any other packages.
Thank you in advance.
MNBigfoot
MN
Ten minute job, if you don't do the recalibration (which you wouldn't do for any of the 50 other aftermarket bumpers). A ten year old can do it, it's six bolts.
*edit, this is a bumper swap, a new one from Ford requires assembly of a bunch of parts. Still a home job that anyone can do.
SHOCALL
Joshua
MO
25 Bronco BadSaS, 19 SHO PP
Easy job without sensors to relocate or fog lights to delete (capable). You can do it.
Cost depends on where you get uour bumper from.
The official Ford one is about $1,100 (but frequently with 15-20% discount and can use Ford Points)
Takeoffs aren’t uncommon and run around $500
Chinese knockoffs run around $300.
Not sure what salvage yard prices are
Colohunter
Jerry j
CO
2025 Bronco 1995 Bronco
Thinking about doing this upgrade also. But mine has the sensors. What else is involved with this type of upgrade.
MNBigfoot
MN
Mistake on my earlier post: What also is needed is either cutting off your tow hooks (the mod bumper has shackle mounts), this is a 3 minute job with a sawzall or cut-off wheel, or the alternative is getting the different intercooler mounts (that come with OEM kit, if purchased new).
Here is the link to the bumper WITH sensor holes.
https://www.ford.com/product/bronco-modular-front-bumper-w-park-aid-p4000210980
NC_Oak
2024 4 door 2.3 sasq
I replaced my plastic with an aftermarket. Still required the recovery hooks to be removed. You can unbolt the assembly from the bronco and cut them off a bench. It's easy. I used a cutoff wheel.
I believe the Ford kits come with the new intercooler mounts that don't require any cutting.
If you buy a takeoff or cheap chinese knockoff - then yeah, you either cut the tow hooks off (they are built into the intercooler mount for the plastic bumper), or you replace the intercooler mounts yourself (about $150 for both if I recall)
*edit*
I wrote all this, and then I see you literally said all that in your post as well - sorry. I blame my teachers, I never learned to read so gud.
Mike leggiero
Ky
if your near ky i have on in storge i will sale
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
What bumper do you currently have?
I just replaced my Capable Bumper (with sensors) for a Modular Bumper, nothing difficult about it.
Dependent upon the bumper you have it may be necessary to replace two of the sensors and un-wrap and re-wrap the harness to make it work.
If you have the Modular Bumper I can provide additional details.
Colohunter
Jerry j
CO
I have the cheap plastic stock one.
Neps
You can check to see what type of sensors the Plastic Bumper uses. I takes about 20 minutes to remove the bumper the first time. After you know where everything is located and how to remove the covers it takes about ten minutes to remove one.
I can tell you that the Capable Bumper uses sensors that have a connector parallel to the sensor and the two outer sensors if installed in the Modular Bumper do not offer sufficient clearance for the connector. So you'd need to replace the outer two sensors with 90 degree connector (sensors) so they do not hit the inner bumper structure.
Capable bumper uses these sensors.
Modular uses these sensors.
The Capable Bumper also needs to have the sensor harness un-wrapped and reconfigured to allow some flex in the harness to fit in the modular bumper. I took my time and installed new sensor housing retainer brackets (my take off MOD did not come with any). Installed the sensors, harness and reinstalled the bumper in about two hours- this also included cleaning and installing cable tie anchor tabs, because the capable harness needs some additional support as it needs to be routed slightly different than the harness made for the Modular Bumper.
