Questions about Flowmaster Part Numbers
5111
DFW, TX
2024 Bronco
I’m looking at four different catback systems. Two are Outlaw and two are Flow FX.
Outlaw 818144 and 818101 appear to be exactly the same, except that one costs nearly $300 more. What’s the difference?
Flow FX 718146 and 718122 also appear to be the same thing, but one is $40 more. Why?
Also, the catback systems are all on sale, so cost the same or less than the axle back systems. Are they essentially the same with extra piping, or is there a performance difference or diameter difference in the pipe before the mufflers? Can I buy the cheaper catback and just install from the axle back? Is there going to be any sound difference?
Any help is appreciated.
DFW, TX
2024 Bronco
4-door
all 4 kits are 409 stainless
Fly by Nite
Walt
Pa
two door/four door
That's it. The 4 dr system needs to be longer. Odd that the Flowmaster site doesn't show the correct pics for the 2 dr vs 4 dr systems. Slackers!
The Borla cat-back system I bought has an extra extension pipe to use on the 4 dr. Just leave it off for the 2 dr.
If you buy a cat-back, just install the whole thing, it's easy. If you try to just install the rear pipes, it may not match up to the Ford front section.
DFW, TX
2024 Bronco
Yes, I realized that later. Thank you for the information.
Chilli9880
Paul
Erie, PA
2022 Ford Bronco
I was interested in the same question, so that you for the answers. But I have another question. How do I know whether to go with the Cat-Back or the Axle Back? Or do they both fit and it's all about preference? I have a Bronco Wildtrak, 4 Door, 2.7L
