PSA: be careful when pulling out tail lights
GroovyGeek
Boyan
'23 Bronco BD
Was replacing the incandescent light bulbs with Oracle LED ones this weekend. Boy, is Ford's design dumb, starting with the ridiculous "screw in" pushpins and ending with the need to remove the fenders and pull not one but two plastic body panels off.
Speaking of body panels - be VERY careful when pulling the corner pieces. The clips are extremely tight and require a good deal of force. Also be sure that your panel tool (or fingers) are fully behind all the plastic. Ford chose to attach the clip mounts to the panel in a relatively flimsy manner and if you pull at the wrong place you will tear them apart.
See pic below and ask me how I know. The sharpie marks were already there, not sure what this is all about. The panels are easy to glue back together but if there is one place where Ford should have used the pull-apart pins that is it.
Ford Bronco PSA: be careful when pulling out tail lights 1000004314
RagnarKon
Ford Bronco, Escape, Focus
Those are the result of QA checks. (In case you wanted to know.)
GroovyGeek
Boyan
'23 Bronco BD
If that is the case it is strange that they chose to use an X for passing QC.
CM81
NA
Good to know. I was looking at getting a pair of those oracle lights. Looks easy on the install vids, but they always make pulling panels off look easy
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
X is unambiguously an X when viewed from all directions.
GroovyGeek
Boyan
'23 Bronco BD
Other panes in the Bronco I have pulled off are quite easy, but this one was tight. The retainers on the side of the car also are shown in the videos to come off quite easily, but mine too some work. There are multiple videos on YT that offer downright wrong or weird advice. The best one I have seen is this
