ProCal Tuner mount solutions
Trueblue2296
Adam
Tennessee
2021 Badlands, 2022 F250 Tremor 6.7L
I just recently got the pro cal tuner and I’m looking for a mount that I can put on my BYOD mount from archetype racing. Has anyone found something that might work?
Gluestick
Josh
Nashville
instagram.com
Explorer ST, Bronco Badsquatch
I'm not sure I see the value in mounting the device. I keep mine in the glove box to read a CEL if I get one, but that's about it. I didn't find a lot of value in the gauges, especially the poor display and visualization options (comparing to using the iOS app for my JB4 on another vehicle), and once you program the tune for the engine or the steering rack, the device isn't really useful. Like if you wanted to change tire size, you can grab that thing and do it, but then there's no need to keep it out.
Trueblue2296
Trueblue2296
Adam
Tennessee
Does it need to stay plugged in? I’m assuming yes but not sure. Thank you
Gluestick
Josh
Nashville
instagram.com
As others note, it does not need to stay connected. You plug it in and run the write script, it overwrites 6 blocks of data in ECU, then it’s done. You unplug device and toss it in toolbox and may never grab it again.
reasons to plug it back in:
- you got a severe duty steering rack and want to program it, and your vin is in their db correctly (ha!) - plug it in, run that write job, disconnect and you’re done again.
- you got bigger tires and want to correct your Speedo. Plug it in, do the thing, unplug it and put away again.
- you get a displayed CEL, you want to read the code and maybe clear it.
adam1991
VW GTI (2)
- Ford updates your tune, and you want to apply that.
Gluestick
Josh
Nashville
instagram.com
I don’t think update the tune itself or they’d have to go back through the various certifications.
Ducati1098
They do update the tune every once in a while. No reason to go back through any certifications for changing small things.
jsoa
Jose
Delaware
2024 Bronco 4dr
I bought this in prep for the procal (until they removed rev matching)
https://a.co/d/dfBkBKG
Not sure what to use it for now
