Problems with installing tail lamps
BronkyCHOO
BC
Bronco base
Hello, I finally just got my new tail lamps in the mail and I’m trying to remove the weatherstripping for my bronco. I use a trim tool with the Philips screwdriver to remove the weatherstripping and it does not budge at all and it’s stripped the bolts and now I don’t know what to do and I’m getting extremely angry when it was supposed to be an extremely easy install please help me. THE SCREWS STRIPPED IMMEDIATELY WTF
i spent 2 hours on it and cant even remove a single one of these screws. Are these fking screws plastic?! Who designed this?! All the online guides make it look like it comes off easy but it doesnt even move! Im EXTREMELY MAD
Ford Bronco Problems with installing tail lamps IMG_3746
orion
Jeremy
17' F-250, 17' Explorer
Get a pry tool behind and put a little pressure on it then lightly loosen the philips screw. Once you get it out you'll see how stupid those are and why they don't screw out. If you can get the head of the screw out, just pry it out then the other part.
BronkyCHOO
BC
Bronco base
I already did that for the past two hours and it doesn’t do anything no matter anything I try to do with it. I followed every single guide and studied them, even a week before receiving these tail lights.
BronkyCHOO
BC
Bronco base
I honestly cannot express the level of anger and hatred I have towards whoever designed this. I followed the instructions exactly. Now half the screws are stripped. Please sos help me
orion
Jeremy
Then get a razor blade and try to get the screw head out enough to get your pry tool behind it. Pry it out then the other part.
Are you using a forked prying device like this?
Ford Bronco Problems with installing tail lamps Screenshot_20251219_193614_Chrom
orion
Jeremy
Don't push into the Philips head hard at all. Just lightly put pressure on screw. There's not enough thread engagement on the screw part. Thats why I said to pry on the part the screw goes into to put more pressure on the threads so it threads out, but you can't put a lot of pressure on screw or it just spins...
BronkyCHOO
BC
Bronco base
Like this? Trust me man ive been doing this for literally 2 hours now. WTF
Ford Bronco Problems with installing tail lamps IMG_3748
BronkyCHOO
BC
Bronco base
Well the fking screws are stripped now; they stripped immediately.
orion
Jeremy
Well the fking screws are stripped now; they stripped immediately. This ruined my goddamned christmas. Fk ford
Take her easy. It's basically just a push pin like this...
Ford Bronco Problems with installing tail lamps Screenshot_20251219_194314_Chrom
...but threaded. Get a razor blade and pull the head out enough to get your pry tool behind the Philips head and pry it out. The screw part of them is a joke, just pry the center out, then pry the other peice out.
STC Bronco
2024 Azure Grey WT
You’re not alone in your frustration. Perhaps your best course of action is not to try and finesse these cheapo plugs and instead be resolved to the fact that some may have to pry out and be affordably replaced. I’ve had to do that elsewhere on my Bronco. This thread may help. Make sure to read it all since it drifts a bit in the middle. https://www.bronco6g.com/forum/thre...-plastic-screws-to-access-brake-lights.52676/
BronkyCHOO
BC
Bronco base
Thanks for the info. I ended up just prying the shit out of them until it came out and I did a little damage to the car.. brand new car too really nice. Now I can’t get these undone. They just turn in place.
Ford Bronco Problems with installing tail lamps IMG_3749
jsoa
Jose
Delaware
2024 Bronco 4dr
For what its worth, this is my technique
- I never use a screw driver anymore
- pull screw out a bit, using pic tool
- use pry tool to pull out screw more if needed
- use pry tool to pull out entire clip
Ford Bronco Problems with installing tail lamps PXL_20251220_041148594
Ford Bronco Problems with installing tail lamps PXL_20251220_041245150
Ford Bronco Problems with installing tail lamps PXL_20251220_041302037
Oldhippie
Barry
Santa Cruz, Calif.
they totally suck…I replaced all mine with rivnuts and real screws…just pry them out and replace them…
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
I've had about a 99% success rate with them. Like @orion said, it takes a little finesse. Make sure you have the correct size Phillips (#2 maybe?). Gently hold the screw driver with two fingers and put very little axial pressure on the screw portion with the screw driver. Just enough pressure to keep the driver engaged in the screw. Then gently turn CCW until it bites and let it back out. Push too hard and it will NOT back out. You might have to hold the outer bushing portion to keep it from turning. I've had my wheel well liners out a few times and have managed to reuse all them little plastic bastards.a few times. You can get replacements at NAPA or other auto parts stores if you mangle one or two. It's certainly not a reason to hate your Bronco. I'm amazed at the engineering to achieve just barely good enough and cheap as possible...and quick on the assembly line.
Bruinsfan
Fury
Great suggestion. I have been there too and used a utility knife on the screw head. After finally pulling out the screw tab, I replaced them with a better user-friendly assembly that I bought online.
