Pre wired to 22 bronco without ordered switches
jjsgroi
New york
2018 mustang
My fault not to order uplifter switches so my question is are the pre wiring still in overhead and other junction in my 22 base two door bronco and can I remove sun glass holder and access the wiring and be able to install my own switches or even factory assembly
Ducati1098
No. You’ll need a different harness and battery junction box, along with the aux switches.
RagnarKon
Ford Bronco, Escape, Focus
It's possible, but not easy nor cheap. You have to rip apart the entire upper trim section, the A-pillar on the passenger side, and install an entirely new battery junction box to wire it in.
jjsgroi
New york
2018 mustang
jjsgroi
New york
2018 mustang
Thanks for replying I guess i not doing that. But are the wires there and from what you say I think you said the pre wired are in the pass. A pillor so I was going to reroute them to top of dash and put my fog and bumper lite switch next to traction switches. I guess I'll have to find a wire diagram
jayr1959
Jay
Delaware
2015 Jeep JK 2DR 2008 Saturn Sky Redline
My wife and I did the install (and were still Married). The hardest part was reinstalling the air bag bolts. That took an hour. The full install was 4 hours. The wallet suffered as the total cost of the parts was 770.
35tires
'23 Bronco, '21 4Runner
I'll go further and say it's absolutely NOT worth it. I needed it so bad when I got mine and the order was wrong I dumped almost 1k in to the project and it took ages.
There are a lot of much better options out there for far less than what that project cost me. sPOD, Switch Pros, etc... I promise you, far better ways to go. Just find a nice place to mount them.
As a weird aside, because I added them and not ford I was refused warranty service for an electrical issue from one dealership.
Full stop, learn from my mistake. Don't bother. Get something alternative and remove it if you sell the vehicle.
The OEM upfitter switches don't do anything that an aftermarket switch will do, at 1/5 the price and 1/5 the difficulty of installation. Other than look OEM.
If you are just after auxiliary switches, there are dozens of aftermarket options at all various price points, switch styles, and number of points. I even recall seeing a wireless one that's pretty easy to install.
Regarding wiring - you will not have the wiring up to the top of the dash where the sunglasses holder is. And you won't have the upfitter panel under the hood - those are part of what you would need to buy ~if~ you wanted to go OEM. All the black wires in the diagram - you won't have.
But there are 5 wires that are pre-run that you will have -- B1/B2/C/D/E. They don't go to anything at all - just pre-run wires in some convenient locations.
Ford Bronco Pre wired to 22 bronco without ordered switches 1705256828232
RagnarKon
The wiring harness isn't even there. You have to buy the correct wiring harness, rip everything apart, install it, and put it all back.
JC2DR
Joseph
Maine
Bronco Base 2dr 2.3 7speed
That would be a huge pain, both in time, energy and expense. Just use trigger wireless switches.
jjsgroi
New york
2018 mustang
Thanks for replying ..going different route
Area51BS
Ron
Badlands non SAS 4dr 2.3
If you don’t want to replace the harness or swap fuse box. Just buy the switch panel. Run your own wires. Have the switches control relays for high current devices. Would be just like doing aftermarket except using OEM switches which looks the best IMO.
jjsgroi
New york
2018 mustang
jjsgroi
New york
2018 mustang
Thanks for replying going to try to install where trac control switches are
