- Joined
- Dec 31, 2021
- Threads
- 39
- Messages
- 1,575
- Reaction score
- 3,520
- Location
- Western PA
- Vehicle(s)
- '22 BadSquatch, '02 T/A
- Your Bronco Model
- Badlands
- Thread starter
- #1
I have been following the issue of the wipers very closely for sometime as it drives me crazy to the point of wanting to trade in my Bronco on something else. Lately, I have hypothesized that the issue is NOT bad or oversensitive motors, but rather too much friction on the wiper blades resulting in the motors doing what they are designed to do and slowing down.
I believe one possible issue is that the wiper arm springs are too tight, thus pressing the blade onto the glass too hard and creating too much resistance when wiping. Go lift up on the blade, then try a different vehicle and see - my wife's Pacifica wipers are much easier too lift up. So, last weekend, 3/25/23 and 3/26/23, I tried to remove the driver's side wiper arm to see if I could go find a lighter spring, or try to stretch the spring. I was not able to remove the arm, but I removed the nut and tried pulling up. Then I played with the passenger side to see if I could shim the spring coils a bit, but wasn't able to. However, the end result was me lifting the wipers several times, and pulling up on the driver side arm. Monday, 3/27 I drove home a few miles in the rain and the wipers actually worked! No slow down or intermittent!
Last Friday, 4/31/23, I lifted my wipers around noon, and left them up overnight to see if I could stretch the springs that way. The next day, 4/1/23 (I know, April Fools but I already had my fun in another thread) we got some rain. My first try was as normal where they went for 20 wipes, slowed down, then on the 25th they went intermittent. However, it wasn't really raining and I was stopped. Restarted and they lasted until I got home, and I even took a detour to extend how long it took me to get home.
Both times they worked in the above instances was not for a very long time, but certainly much longer then they had ever worked before. Oh, and a disclaimer, I use synthetic wax and put it on my windshield, but it has been over a month since my last wash.
So, why not try lifting you wipers overnight for awhile and see what happens? Its free and easy, what have you got to lose? Please report back and let us know what happens.
The second thing I recently came across is that @Ground_zero298 reported in another thread that he dropped down to 15" blades and hasn't had an issue since. This also seems to support the wiping resistance theory, as less contact area will result in less resistance. So please feel free to try this and report back.
Lastly, @E. J asked if checking the linkage for binding and adjusting might help, this might also be an area to look into.
https://www.bronco6g.com/forum/thre...sue-fixed-thanks-to-ford-motor-company.70071/
https://www.bronco6g.com/forum/threads/wiper-control-speed-issues-urgent-safety.31809/
I dropped down to 15” wiper blades. Haven’t had a issue since.
Last ride out we went through a wet snow storm. 4 of us. 2 had intermittent slow done. Mine ran fine.
Relevant threads:Has anyone checked (or know if dealer techs are) the linkage joints for proper movement? Like being overly tightened. Could be a contributor to the problem.
drawing source
