Popping, clunking when stopping
BroncoBeachBuggy
Montauk, NY
F-150
I figure this won't be covered under warranty. Went from stock BD 265/70r17 tires to 285/75r16 E load. A lot heavier than stock, but still a little lighter than SAS tires and wheels. Figure with HOSS 1.0 dealer will nix warranty with these heavier/wider tires. Only 12.2k miles on BD and about 1.5k with new bigger/heavier tires.
Anyway, coming to stop (even without brakes by downshifting 7MT) popping and clunking sound drivers front tire area. Guessing tie rod, end link, shock, bushing, wheel bearing, steering rack/stabilizer... could be anything. Who knows until it is looked at by my mechanic. One thing I will check tomorrow is lug nuts, but I doubt it as safety checked two weeks after new tires were put on.
My question is... any common/known points of failure with HOSS 1.0 to look for first with aftermarket tires/wheels that weigh close to SAS tires/wheels?
PWillette
Parrie
Maine
That jump in tire size shouldn't be a reason to deny warranty IMO.
Any other mods or recent work on the front end? Possibly the LCA bolts are loose.
Mike leggiero
Ky
dealer doesnt care about tire size i run 37s on both of my broncos. one is a base and the other is a bd.
cbrownabq
Littleton, CO
Dodge 2500 diesel
I have the same issue but, I'm lifted 2 inches with an Antirock sway bar. Ive been trying to hunt it down. I think mine may be lower control arm bushings. The good news is that I found some nuts and bolts that needed retightened. But it still clunks.
cbrownabq
Littleton, CO
Dodge 2500 diesel
Any progress with this?
