*Poll* Rock Slider Suggestions?
Out of the options below, which rock sliders do you like best?
  • LOD Off Road - https://lodoffroad.com/products/2021-ford-bronco-signature-rocksliders
  • GOAT Fab (WITHOUT top plate) - https://goatfabrication.com/collections/4-door-bronco/products/goat-b
  • GOAT Fab (WITH top plate) - https://goatfabrication.com/collections/4-door-bronco/products/goat-bron
Results are only viewable after voting.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Frame mount is best, but I wouldn't want to mess with welding or drilling the heat treated frame, I'd look for one which don't require modification and there are a few.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
How have these been with preventing rock chips on the side of your Bronco? How long have you had them installed for?
I have had them on for about a month. They seem to block the majority of the rocks/mud slung by the Territories, but I haven't been down a heavy gravel road since install. The Territories pick up everything and certainly hear much less body "tings". I went through some mud and was surprised at how well they blocked the mud sling. As you can see from the pics, they nearly extend out to the edge of the SAS tires and have already protected from a door ding once.
https://www.bronco6g.com/forum/threads/goat-rock-sliders-now-with-top-plates.51982/page-2
I know frame mounted are best, but there have been lots of comments on the research Ford and the designers must have put into the factory sub-body location/reinforcement. All hardware is upgrade to longer grade 10 bolts with these. After these vids I decided this would be sufficient for my use and I liked the tighter tuck/profile.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
get the @GoatFab sliders! They're on sale right now too!
Jdyount
Jason
Kansas
2021 Badlands
This video actually makes me even more against the body mounted rails. Throughout the whole video you can see the rail is actually bending up making contact with the body. I don't like that at all. I've had some very hard slams coming off ledges and I really think I would have had some body damage with those.
The stock rails are tucked under and there isn't nearly as much of a lever. With these rails coming out, there is a lot more torque being applied to the mounting locations.
Chritaka
DFW, Texas
Incorrect, watch the vids in slow motion... Where does it make contact? It is not "bending", it is flexing along with the body, and there is NO body contact ever. Watch RCI's vids, theirs flex just as much, but no body contact is ever made.
Jdyount
Jason
Kansas
2021 Badlands
You can actually see that something has been into the rocker in multiple places on that Bronco
Ford Bronco *Poll* Rock Slider Suggestions? 1681491967475
And if it's going from that much gap (above) to this much gap (below) it's hitting something on the body. The pinch weld, the rocker, somewhere it's making contact.
Ford Bronco *Poll* Rock Slider Suggestions? 1681492107566
Chritaka
DFW, Texas
Obviously those dents were already there, they abuse the heck out of their truck on the trail and in testing. You would need an extremely sharp flex to do that from the slider, where it would not return to form. Not possible from physics and the entire unit flexing as a solid piece. The whole rocker would be caved in, not a few inches in 2 different spots... You can inquire from @GoatFab further if you like.
2nd pic, it doesn't touch, you must remember your' viewing from a near completely horizontal view, not overhead. Did you watch the 2nd vid?
To each their own, I have no skin in it, but I'm an extremely detail oriented and analytical person and did my research. Up to you to do your own.
GoatFab
MI
2021 FE Bronco
Sorry but those dents were done before sliders. Those are actually from forks from a hi-lo There are now 100's of sets in the "field" now. Not a single issue with these deflecting or Bending. We have tested extensively.
We are not going to offer something that hasn't been tested. Why would we offer something that bends deflects or breaks. That is not a business plan that will work.
My goal is to offer the strongest slider/step on the market.
We do also offer a weld on to frame version should you think you need it. (90% of people dont) even those that wheel hardest trails and rocks.
Thanks
Adam
Jdyount
Jason
Kansas
2021 Badlands
Lol....sorry....those dents were done before sliders. Those are actually from forks from a hi-lo There are now 100's of sets in the "field" now. Not a single issue with these deflecting or Bending. We have tested extensively.
Thanks
Adam
Ya, I didn't really mean to imply that the rails in the video caused those specific dents, more that the rails weren't doing their job if the damage happened with them on. I got sidetracked and I kinda ran the two points I was trying to make together so that's definitely my fault for the misunderstanding.
So I do still have concerns with the amount of flex I see in that video. It's not your rails that are flexing, it's the sheet metal body where they mount. The factory rails are much shorter and I'd be surprised if Ford factored in adding several more inches of a lever in their engineering of that mounting point (for use with steps yes, more than likely not for bouncing sideways off a tree).
I mean the same could be said for a frame mounted set of rails, but at least the frame is structural and not stamped sheet metal.
I hit a tree so hard with my frame mounted rails a few months back that I was concerned that I bent the frame. I have no doubt in my mind that those body mounting points your rails use would have had permanent deformation, no doubt.
For me it all depends on how much protection you want (and want to pay for). Are these better than the stock rock rails, sure, are they going to suit the needs of a more extreme rock-crawler, probably not (which is why you also sell a weld-on frame mount set).
Ford Bronco *Poll* Rock Slider Suggestions? 1681496548778
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
FYI: I can tell you first hand , these do NOT bend or deflect in any way. I have had the full weight of my Bronco on them and they are good to go . I tested them at trail hero last year, the bottoms are scraped up, but they did their Job.
Look at the way they mount on their web site, they are beefy mounts to the under structure not pinch seam.
https://www.bronco6g.com/forum/thre...at-sand-hollow-plan-b-and-double-sammy.56112/
604Bronco
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Thanks
Adam
Thanks @GoatFab - I dropped you a DM this morning with some questions :)
604Bronco
604Bronco
British Columbia
www.bronco6g.com
Another for Goat, you can order with top plates like mine. They’re sub-body mounted, but the mounts are stout. They have several vids showing the abuse they can take, as well as several members confirming they can support the truck weight/abuse RL.
Is that top plate welded on, or can you actually take it on and off?
