Oem rock slider info
BronkyCHOO
BC
Bronco base
Hello, I am looking for information on the OEM rock sliders from Ford, and if there are side steps that will attach to them.
I remember seeing something a little while back about it. I saw some cheap but good option that just hook up right to the rock sliders.
Area51BS
Ron
Badlands non SAS 4dr 2.3
You can find take offs easily online. The steps are available from IAG
Ford Bronco Oem rock slider info IMG_6059
Area51BS
Ron
The steps also install and remove in a minute should you want to off road where rock rails would be needed.
Valhalla
Valhalla
Chattanooga Tn
If removing steps for offroad there are cheapies on sites like ebay. Once stock rock rails are added. I no longer bolt my cheapies on as they snap into place. Quicker to remove.
BroncoChallenger
2024 Bronco
If you're looking for inexpensive but sturdy steps for the factory rock rails, Mountains2Metal have a good set. They're relatively inexpensive, and just putting them on they're pretty snug. They have a set screw on the back side to hold them in place (safety). They're not overly big - they're a step, not a running board. They also hang down kinda low, great for entry but not so great for serious off.roading so you'd want to take them off for that. Overall I like them.
BronkyCHOO
BC
Bronco base
Please send me a link, i like square 2 steps on each side
VirginiaHeritage
Frank
‘25 Bronco HE
Definitely want to do this myself, too.
The ginormous ‘25 factory tube steps make me feel like my Bronco has a skirt on.
BroncoChallenger
2024 Bronco
Sounds like you need to head over to Mountains2Metal and look at those. They're kinda square-ish, depending on if you have a 2 or 4 door you'll need 1 or 2 sets.
Valhalla
Valhalla
Chattanooga Tn
Just search on ebay, I found some 200$ 4 door ones and chopped them down for my 2 door.
